Question about Delphi Roady XT XM Radio Receiver
Roady gone wild
Have had the Delphi Roady XT for 14 months. Was working great at home and in the car (w/ the home adapter kit). First problem was when the remote stopped working: new batteries, cleaning, but no workee. Has continued to work well in my truck, however, a once pristine home antenna position (w/ three bars) now gets zero signal. I do live in the woods, w/ a somewhat obscured southern exposure, but the thing had been working fine. I got on the roof w/ the antenna and have tried every solution I've read about on line. Now the receiver is turning off by itself, muting itself, and occasionally runs through the channels all on it's own (I've moved it to my classroom, which has a clear southern exposure). I'm really upset w/ this thing, and I'm ready to switch to Serious. Also, not very impressed at all w/ XM's troubleshooting help, either on phone or on line. Any ideas?
  • 1 more comment
  • Anonymous May 12, 2008
    Roady XT does not show display anymore
  • cpo1563593 Jul 14, 2008
    Same here. I've purchased the home kit, car kit and boom box. I also purchased my seond receiver and have the same problem. I have the signal but there is no sound. I agree, the online help is useless.
    I think there is a problem with the receiver itself. If you switch your receiver between your home and car, it will more than likely develop this problem.
  • sparrky Aug 21, 2008
    switching channel, going to mute and shutting off. some times in a hour and sometimes in 15 minutes. I have examined contacts, made sure there is power to the unit.
Called service and they asked if I had a remote close to the unit, I did and they suggested that the battery was low on the remote possibly. I took the batt out of the remote and several hours now with no channel changes or shutting off. the second thing was to make sure that the power adapter was giving steady current.
Posted on Aug 25, 2008
  • sparrky Aug 28, 2008
    Mistake in thinking that removing remote control fixed the problem. only seem to work for a few hours. checked the voltage and it was at 4.85
  • sparrky Sep 05, 2008
    After trying different situations, found in vehicle and on Motorcycle unit worked fine for extended periods of time. back in shop where I leave it on 24 7 if I don't used somewhere else. found that when it changed channels voltage was less than 5 volts. I used a power supply 110 volt to 12 volt, hooked my car adapter that goes from 12 v to 5 volts to the unit and immediatly it worked fine. volts on the supplied adapter that goes directly from 110 volts to 5 volts was putting out 4.8 volts and the car adapter would put out 5 volts. The 110 volt adapter after not being used all night would put out 4.95 volts and the unit would work all day untill the voltage dropped. So check that voltage is up
I also have a similar problem.  So I bought a replacement and I still have the problem.  The new radio worked fine for the first 2 weeks but then started to mute itself, change channels, change menu settings and shut itself.  Very frustrating and I am about to cancel my subscription if I don't come to a solution very soon.
Posted on Jul 10, 2008
    Problem Solver:
  • 9 Answers
From the symptoms that you've described, your RoadyXT seems to be malfunctioning. If you once had a signal, you should still have one unless major construction has hurt a signal. Your warranty has probably expired but I these units can be purchased for a very reasonable price. I would suggest buying one cheap off somewhere like Ebay.
Posted on Jan 16, 2008
I'm having problems getting reception with the Roady XT and a home kit in my classroom-thick walls and windows
Your antenna needs to be facing southwest. Try to find a window in your classroom that faces that way. Another way around this if you don't have a southwest facing window is to get the XM repeater that will allow you to have the antenna in one room, and your receiver in another. I have two (one at home, and one in my store, and they work great).
Jan 31, 2010 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT. Changes channels by itself. Can I fix that?
Try a new wall plug/adapter. You need the 5V adapter from Belkin. Worked like a charm for me--after suffering with this problem for a week....only cost $10.
Jan 08, 2010 | Delphi Roady XT XM Radio Receiver
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT won't turn on
Same here, it's nice to know I'm not the only one with this issue at least; but as to a way of solving this, I've found nothing.
Dec 07, 2007 | Delphi Roady XT XM Radio Receiver
Xm radio
mine does the same thing.
Nov 03, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
441 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
