My wpn111 wireless adaptor keep dropping my router signal
There is very little you can do about this. You may not like that answer, and I am sorry for the trouble, but there are things you can try.
First, lets understand that wireless is a radio signal, much like a cordless phone. The handset has to be able to communicate with the base on a phone, and, the wifi pc's have to be able to communicate with the router. Some phones and routers (sadly) use the same frequency range, 2.4 ghz. If you have a cordless phone that operates on 2.4 ghz, or if your neighbors have one, then whenever they get a phone call, wifi goes bye bye. What can you do?
1. Upgrade your phone to a wifi friendly one, with a 2.4 ghz offset range (so that the bands are close, but not so close to cause interference) or get another frequency phone.
2. Change the frequency of the router to level 1. Usually they are AUTO or level 6. Level 1 is a low frequency, and lower frequencies usually give slower, but more reliable performance. You can choose between 1 and 11. try all frequencies to see which one gives less trouble.
3. place the router in a more centered location in the home, off the floor. Remember, this is radio. Radio antennas go into the air to receive signal, and your router is no different. A router stuck in the corner of the basement may give poor performance, while a router in the center of the home should service the home easily.
4. upgrade your wifi. Choose the wireless N router and adapters for your machines. they have better capabilities and less interference.
I hope this gives you insight into the issue. Wireless is at the mercy of its environment. Building structures, signal interference, power lines, atmospheric issues, and cordless phones can play a factor in your reception. its just like taking a portable tv thru the house and having to move the antenna around to try to get better signal. Good Luck.
it want call out
yjgyuh
Mine was not caused by WiFi. I purchased my phone 2nd hand ESN Clear, supposedly 100% working but when I switched over my ESN and attempted to dial out to reprogram the phone, I got the same error. I called Verizon and they helped me by doing a soft reboot then a master reset but to no avail. I then took the phone to the Verizon store to make sure it wasn't just me and they couldn't get it to work either. I have since reprogrammed my old phone and await a response from the seller of this "new" to me phone. Very frustrating that no one has an answer, YET.
I have the same problem. How can " wireless radio" error pop up and it's not even in the owners manual. My son has been using his phone when it went out. Verizon can tell you a million ways to fix it, but all you end up doing is losing your information and the phone still doesn't work. Has anyone contacted Audiovox to complain? I know I won't ever buy their product again.
Upset
i have the same problem it dousnt work im only twelve i worked for a year to save up enough money to buy my new phone and it dousnt work i am very mad...
