Question about Dell Axim X30 Pocket PC
Menus scroll by themselves
I just purchased a used x30 and in working with it I've discovered that after a few minutes of navigating around, the menus will start to rapidly scroll through their options and the PDA will stop responding to anything I do. For example, if I hit today's date on the calendar, it will bring up today but will then immediately scroll through subsequent dates (it only takes about a minute or so to get up to 2010...). Or if I hit the start menu, it will highlight one menu option after the other, top to bottom then back to the top.
The only way to get it to stop is to turn the power off, but eventually it happens again next time I use it. Is there a way to permanently fix this?
    Sergeant:
  • Dell Expert
  • 400 Answers
Time to replace the mouse and key board
Posted on Sep 17, 2018
3 Suggested Answers
SOURCE: Touch screen not responding correctly
The Axim touch screen is extremely sensitive to the placement of the protecting plastic sheet. Check that the the plastic sheet is oriented correctly - the small bended corners must bend downwards. If that wasn't the problem then remove the protection sheet and pick gently directly on the screen with the stylus to see if you get a response. Most often this is due to a problem with the screen protecting plastic sheet.
Posted on Aug 20, 2008
  • 10 Answers
SOURCE: PDA clock and appointments change at sync by one hour
I am running vista and havent had this problem, as a matter of fact if you have vista you no longer need activesync. Vista comes with a built in software application to sync you PDA, there si no logical solution i can think of that would cause this problem other than your computer may need to be updated, and also vista will update all the drivers for the dell x30 as well, just make sure it is able to do all updates, not just microsoft ones.
hope this works for you!
Posted on Mar 27, 2009
DISPLAY SETTING T6050 PRINTER
I'm not 100% sure what you are asking here, but on that printer to navigate the menus is a bit odd. Scroll to the option you want and press the key with the '1' on it then scroll to your next option and press the key with the '2'. The next menu option uses the '3' and finally you would use the enter key to display the value for the option that you navigated to using the '1,2,3' keys.
Jan 05, 2016 | Tally Line Matrix T6050 Printer
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
Jul 30, 2014 | HP DesignJet Office Equipment & Supplies
A restore was done on laptop but not got bluetooth now.where can i find it.
I will help you personally myself.
I can fix it within a few minutes, i've you grant me access to your computer remotely.
For example:
TeamViewer
http://www.teamviewer.com/en/index.aspx
Jun 04, 2011 | Samsung X30 PC Notebook
I cannot connect any more to my motorola rasor phone, after I updated maps
If you can't connect your navigation device to your mobile phone try the following:
  1. Make sure you have the latest application installed on your navigation device.
  2. On your mobile phone, remove all Bluetooth bondings.
  3. If possible, remove the battery from your mobile phone for a few seconds, then re-insert the battery.
  4. Turn your phone back on and make sure that Bluetooth is enabled and that the phone is discoverable for other devices.
  5. You can establish a Bluetooth connection between your navigation device and your phone.
    The method used depends on the type of navigation device you have:
    GO 1000 series, Via series, Sony XNV GO x50, GO x40, GO x30, GO x20, GO x10
    Blue&Me TomTom, Carminat TomTom
    DAIHATSU, ECLIPSE, TOYOTA, MAZDA
    Rider
Mar 28, 2011 | Tomtom GO 910 GPS Receiver
What navigation software can I install on a Dell Axim X30?
Glad to help YOU!
Correct me if I am wrong, but as far as I know this Axim X30 is still using Windows Mobile 2003 SE. It has a processor that runs at 624 MHz and you have about 64 Mb as internal memory; you can also use an SD Card in the slot up to 2 Gb.
Here is a list (accordingly to my knowledge...!) of the navigation software that you can use on your device:
# iGO
# CoPilot Live
# Garmin
# Navigon 6
# TomTom
Each software can be purchased online from the manufacturer's website. I suggest you - before you will buy - to check if are maps available for the area you are living in!
GOOD LUCK!
Mar 16, 2011 | Computers & Internet
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
Cant connect to internet using my dell axim x30 helppppppp
http://www.fixya.com/support/t1775615-connect_internet
just answered this for someone else, if you have any other problems get a hold of me on twitter @clarkb16
Feb 23, 2009 | Dell Axim X30 Pocket PC
Close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Jun 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Samsung DVD plater HT-X30
Try to burn your cd with CD-R 650MB/74 mins.and play: i believe it will work.
Apr 03, 2008 | Samsung HT-X40 System
Dell Axim X30 Pocket PC Logo
162 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
