Question about Sharp R-1405 / R-140 Microwave Oven
Microwave possible blown fuse??
I have a Sharp Over the stove microwave Model R-1480 manufactured July 2001. This microwave is in my motorhome & I hooked up my motorhome by mistake to 220 volt and now I have a T.V. & microwave that does not work and there is power to the receptacles?? After taking this "attack of dumb" I reset breakers and GFI receptacles and everything else started working but these two items. I am hoping there are fuses in both of these however I don't know where they are located and if indeed they even have fuses??
Thanks so much in advance for your input, it is appreciated.
Respectfully
Lonnie McIntyre
  • Lonnie McIntyre Dec 06, 2007
    Thank you so much for your help, it is apprerciated. I did find the fuse in the microwave but unfortunately the fuse is good. I have 120 volts on both sides of the fuse. So I am now stumped as to what the problem may be. This over-the-range microwave is in a motor home and I think they built the coach around it and I can't follow the wires properly without removing an additional panel which I can not get access to the screws without removing the microwave?? Go figure.
    However on the bright side. I did take out the TV to find a blown fuse. I just have to find out where I can purchase one? I am going to go to Radio Shack and see what they have. Again, Thank you so much for your input I found it very helpful.
    Oh by the way, I am located in Homosassa Florida.
    Respectfully
    Lonnie
  • Sharp Master
  • 9,098 Answers
If you still have this oven and need repair, we can do it for $39.95 nationwide or about $25 more if it needs a new transformer.
We repair these and various other models all the time with the same situation for RV owners & dealers across the country.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 20, 2008
  • 22 Answers
Hi Lonnie,
Yes, both of them should have a fuse or two in the internal power adapter. If you open them up, you should be able to find it fairly easy (start tracing from where the AC power line comes in on the board). Make sure you unplug them and leave them unplugged for a good time
Once you find the fuses, you can take them to a local electronic parts outlet for identification, testing, and replacement. Most electronics places will have a meter on hand and be happy to do this for you for free.
Since you didn't give a city location for yourself, I'm afraid I can't offer a local store recommendation.
As always, when working on a TV, be VERY careful to make sure that the capacitors are discharged. See this faq:
http://www.repairfaq.org/REPAIR/F_captest.html#CAPTEST_003
Posted on Dec 05, 2007
  • Michael Ahlf Dec 07, 2007
    You're welcome, you ought to be able to find an electronic parts outlet fairly close by.
    As for the microwave, visually check capacitors for leakage as your next step. Unfortunately, if it's not that, it is probably cheaper (and safer) to replace the microwave entirely.
What is the color of the sharp r-1480?
The Sharp model numbers indicate the cabinet color by the last number in the model number. 0=Black, 1=White and 2= Almond
Apr 18, 2014 | Sharp R-1480 Microwave Oven
What keeps blowing my fuse on my Sharp R-1480 microwave oven ?
A short circuit diode will do that or shorted turns in the magnetron high voltage transformer, or the magnetron or a sticky/contaminated door switch.
Hope that helps.
Oct 24, 2010 | Sharp R-1480 Microwave Oven
How do I remove my undercabinet R-1480 microwave ?
Take this link to Sharp to view a pdf file of install instructions. The model number is different, but most install with the same methods.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Feb 23, 2010 | Sharp R-1480 Microwave Oven
Microwave died while cooking
Sounds like the fuse has blown. There are some high voltage circuits that exists inside your microwave and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, and you are not familar with high voltage components.
Sep 29, 2009 | Sharp R-1480 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Sharp microwave is suddenly dead. 120 volt power is OK
It sounds to me that the fuse has blown out. this could be fixed at home if you are handy. You don't have to be super handy .I can walk you through this repair. DFD
Apr 14, 2009 | Sharp R-1480 Microwave Oven
Sharp R 1480
This is usually a blown high voltage rectifier diode.
We have the service manual and have uploaded it to our site here.
We have critical safety & disassembly info (including a disassembly how-to video) at our site, linked here.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Sharp R-1480 Microwave Oven
Over the stove microwave install space
I would call Sharp at 1-800-SE-SHARP.
Jul 09, 2008 | Sharp R-1480 Microwave Oven
Dead replaced fuse now makes loud noise
Yes that noise is causing your fuse to blow. Machine gun sound sounds like the High Voltage Capacitor or High voltage diode is bad. (Loud humming sound is usually a bad magnetron or bad power transformer). Most of these parts are inexpensive, except for the magnetron. But most of the repair bill is most likely going to be for labor.
Based on your model, it looks like an over the range microwave. And to fix any of these problems require the removal of the microwave from the wall. So its up to you if you want to deal with that hassle. But you also have to consider that you'll probably have a hard time trying to find a new microwave that will fit.
Mar 25, 2008 | Sharp R-1480 Microwave Oven
Sharp R-1405 / R-140 Microwave Oven Logo
1,114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
