Question about Compaq Presario 5000 PC Desktop
Compaq Presario won't boot
Compaq sr1913wm won't boot. Here's the story...I downloaded Spybot and began having problems so I restored what it changed and uninstalled it. Now my pc is having boot errors and wants the recovery disk. I can't access system restore from the start screen (compaq) and windows or anything for that matter won't load.
All fans are working but there is a single beep about every 4 seconds. I've gone into BIOS with no looks like the pc isn't recognizing the hard drive, and has CDR as the first start up.
I'm far from being a computer wiz but have chatted with HP customer support. They want me to send in the pc for the price of $199!?! They also said that the hard drive may need to be replaced. The pc is little over a year old and the memory is only half full.
I just got off the phone with a tech...outsourcing calls to INDIA SUCKS! I guess I'm going to unhook the hard drive and then reconnect it? They said this may help the pc to recognize the hard drive....anybody have any suggestions on how to fix this boot issue?
What I've done...
-disconnected all plugs
-drained power/reconnected power
-tried f8, f10, etc...won't start in any other mode
-screen reads...Disk Boot Failure Insert System Disk and Press Enter
(no recovery I'm trying everything else first...yes I have not backed up info in a while! never again I swear...I'll back it up! forever more!)
What I can access...
-Boot Menu
-Set Up
HELP!!! Thank you in advance!
Re: Compaq Presario won't boot
You have to reformat your pc.find some bootable disk you try window xp and reformat your pc
Posted on Dec 06, 2007
0 characters
3 Points
Compaq Presario SR1610NX won't turn off, and won't
The problem could be a hardware problem.
You can try removing the ram to see if it's faulty otherwise I am afraid you are unlucky because could be a motheroard problem so the only solution is to bring your laptop to repair service.
Feb 05, 2013 | PC Desktops
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Compaq Presario SR1000 won't boot up completely :(
Hi Thanks for your question
I would suggest to enter "safe mode" and then do system restore again. To do this you need to follow these steps.
1.Turn your PC on and press F8 on start up. This should take you to the screen asking what you want to do. 2. Choose safe mode from the list and press enter. 3. Once safe mode loads you should be asked if you want to restore your system to previous state. Just press no to run system restore and follow steps (you already know how to do this)
Shutting your computer down without closing operation system properly may cause start up issues like this one.
I hope this helps you. Good luck
May 26, 2010 | Compaq Presario SR1000T (568657) PC...
My Compaq Presario SR1650NX wont boot the light in the front for the hard drive is yellow and all I get is a black screen but all the other drives load up fine. The fans are all going, and monitors both...
refer to the users manual, or download if possible.
Yellow/Orange could mean that the computer is In Hibernate/Sleep Mode et,c. usually restored by pressing certain keyboard keys Or pressing and holding the power on button For 4 seconds or more.
Other Possibility ( graphics/VGA driver or device, Corrupt Or missing )
You could change the graphics card, Or remove the motherboards Cmos Battery, for 10 seconds, which will restore the Computers Bios, default settings.
Mike @ compurepair.
Nov 04, 2009 | HP Compaq Presario SR1650NX...
Audio drivers
All the drivers you need should be right at the link above..
If not get back to me I CAN solve this problem!!
Aug 04, 2009 | Compaq Presario 5000 PC Desktop
Presario SR1123WM won't restore to factory
If Compaq doesn't have one no one else will either.
  Have you tried the recover clean up utility? Available as a download (link below)
My guess is that if it will not restore something is wrong with the hard drive. Have you contacted HP to ask them what it means?
Another option is to buy and install windows and download the drivers from Compaq/HP.Same link〈=en
Feb 28, 2009 | HP Compaq Presario SR1123WM (PC184A) PC...
Claification to my problem with compaq pressario
Hi. Azrul here. Here is 2 of my best solution for your problem:
1. Online support from your PC's manufacturer. Restart your PC using a Windows XP/Vista CD and download all the related drivers for your PC online (you will need your compaq presario model number for this)
2. There is also an option to purchase the restore disc online. Depending on the age of the PC that you purchased, just google for "Compaq" or "Hewlett-Packar"and get the restore disk from there.
Dec 21, 2008 | Compaq Presario 5000 PC Desktop
My pc runs like ****...i want to restore it
If you use the restore disk it will return it to ME. The only other option for wanting Win 2000. If you have a copy of the disc you merely need to insert it. Then go through the steps to format then install windows. (Note: All information will be lost so back up all important data before reinstalling Windows.) Definetly do not use Win ME.
Good luck,
Jun 15, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
830 people viewed this question
Top Compaq PC Desktops Experts
Michael Thomas
Michael Thomas
Brian Sullivan
Brian Sullivan
Are you a Compaq PC Desktop Expert? Answer questions, earn points and help others
