Question about Philips 60PP9352 60" Rear Projection Television
Fix it Philips 60PP9352 60 in. Rear Projection Television...is my tv, and I think it has a blown fuse in the power supply. Because it will not turn on...no lights, no sound...just nothing. How do I fix it. thanx ......nicole
  • dnswallin Dec 18, 2007
    I may Fuses also out dose anybody know all the fuses on my system 60PP935217 Philips 60" rear projection
    Thanks to all
    Duke
  • hunt3272 Jan 09, 2008
    I have sound but when I turn on the unit there is a flash under the H/V Generator. Anyone can advise me how to fix this. Any help is appreciated?
    Ron west suburbs Chicago
    Genius:
  • 1,153 Answers
Yes, there are many fuses in this set some looks like the regular fuse, others are small pica-fuses. Look for 25-2600, 1801, 1300, 2000-1 these are some numbers you can look for to see if open.
Posted on Dec 05, 2007
My Philips Magnavox 60 in rear projection TV # PTV775-AH01 has no power when you turn it on. How can I fix it?
It sounds like a power supply problem, it could be as simple as an internal fuse (not the fuse in the plug) or something more sinister like a transformer issue which can become expensive, either way i wouldnt recommend repairing yourself unless your confident with electrics and know what to look for
Oct 28, 2014 | Philips 60P8341 60" Rear Projection...
The tv will not turn on at all...no light or anything will turn on..
check at MAIN POWER SUPPLY for a BLOWN FUSE , thats the first thing t look for , thanks AJ
Dec 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Rca tv won't power on
it may need a Flyback Transformer or a burnt capasitor and resistors. there are many posts with this same problem. Some a little different. Check the fuse just inside where the power supply cord goes in . if the fuse is blown you will have to find the reason it burned . But maybe you will be lucky and replace the fuse. And it will turn on. but I think that only a TV technician can fix the problem.I have a background on TV repair and I think it's the Flyback transformer. sometimes you canresolder them and they stay.
Nov 23, 2008 | RCA P52926 52" Rear Projection Television
No picture no sound
most likely the horz output is blown and voltage regulator is shorted. I f you have a muti meter you could check if they are shorted that will tell me if the power supply is ok.
I beleve at this time you should be careful this is high voltage off of flyback is 30.000 volts
See if there is a local repair shop who charges cheap road calls. I think you are
looking around 295.00 to fix.
thanks DOCTOR VIDEO
May 17, 2008 | Philips 9P6031C 60" Rear Projection...
Turns on but no picture or sound.
please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Mar 30, 2008 | Philips 50P8341 50" Rear Projection...
I have a problem
You have a power supply problem. What is the chassis number of your set? Let me know the chassis and I may be able to help you out.
Mar 02, 2008 | Philips 60P8342 60" Rear Projection...
No power to tv
You say didn't do anything, Like did you hear a squealing sound or did you see led lights on front of panel or just dead nothing? If dead and nothing then look for fuse blown in power supply if not then there maybe a small sound coming out of set when you press power if so then the power supply is trying to start up then you will have to look elsewhere like horizontal or convergence or vertical areas.
Sep 18, 2007 | Philips 51PW9363 51" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
No sound no picture
Does any lights come on led on front of set? Does set make any squealing sound when you press power? If not then open and look at power supply board. This is the board that the cord is attached too. look for open fuse, check 2004, 1000, 1300, 1900, etc. See if fuse blown then look for short in pwr. supply.
Aug 29, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
