Question about Refrigerators
Kenmore refrigerator light does not work
I replaced the appliance light bulb in our Kenmore refrigerator
and two new bulbs won't light up. Is there a fuse for this?
Or do you have any ideas why?
It is a older Kenmore Coldspot model 86793810
  • 11 more comments
  • Anonymous Mar 08, 2008
    I replaced the light bulbs, but the lights don't go on in the fridge. Is there a fuse or something that needs to be replaced? The light in the freezer part works.
  • Anonymous Mar 13, 2008
    I had the same problem but put in a regular 40 Watt light bulb and it works just fine. I noticed the end of the bulb on a regular bulb had a longer connection point. Try a regular bulb and see if it works.
  • timennor Apr 28, 2008
    I don't have the same problem (not yet, anyway): I can't get the plastic cover off the light bulb unit on my (much) older Kenmore UPRIGHT FREEZER!
    I know it's probably a simple task to remove the cover, but I can't figure out how to get to the light bulb.
    Please, somebody help!
  • sreynolds Jul 04, 2008
    I replaced the bulb in my Kenmore several times and it still does not work. Is there a fuse?
  • Anonymous Mar 08, 2009
    I was cleaning my refridgerator and I touched the bulb with the cleaning cloth and it shattered. I put a new blub in and it would not work. Tested the bulb in another source and it worked. I tested the socket it had power. Found that the little tab in the bottom of the socket needed to be pulled out a fraction of an inch to touch the bulb. all fixed.
  • Anonymous Mar 22, 2009
    Opened door of Kenmore fridge and light went out. Replaced both bulbs and...nothing. Fridge is plugged in and cold. Must be a fuse somewhere, or bad switch.
  • robnition
    robnition Aug 09, 2012
    Thank you, thank you, thank you....was about to replace switch - this advice saved me an hour of my life! :)
  • Anonymous Mar 18, 2014
    How do I replace the light bulb in the refrigerator?
  • Anonymous Mar 21, 2014
    need width for Kenmore refrigerator model 253.56512400
  • Anonymous Mar 26, 2014
    Sears Kenmore model 106 59432800
    I have a sears Kenmore refrigerator model 106 59432800 serial number HKW2362734. The bulb has been replaced and I pulled the tab out a little where the bulb goes in. Please help
  • Eddie DeMars
    Eddie DeMars Apr 22, 2014
    Adjusted the socket shell connectors that touch the light bulb base touches. Creates a neutral connection..Works fine
  • Eddie DeMars
    Try adjusting the shell connectors that the bulb touches. Be-sure to unplug the fridge from the wall socket first.It will create the natural current that is needed.In order for the light to work....
  • 410 Answers
There is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 3 more comments
  • Ryan W Dec 04, 2011
    I just did this for my kenmore elite trio fridge, had the exact same problem, bulb went out, replaced, but did not work, I just bent that tab and wa la! it works now!! Thanks so much!
  • Alexm21 Jan 08, 2012
    I was about to call an expert for this. Thank you you saved me big time. It really works and is something simple :())
  • rwhitten299
    rwhitten299 Apr 06, 2013
    Awesome! Thanks for the suggestion, worked like a charm!
  • bfish605
    bfish605 Jul 15, 2013
    Thanks, that was all I needed to do!
  • Roni Bryant
    Roni Bryant Mar 28, 2014
    YESSSSSS!!!!!!! THANK YOU, it worked perfectly!!!
Thanks got a new bulb for my fridge put it in and not working . then searched google came across this bent the bottem pin and now light works again thanks guys.
Posted on Feb 09, 2010
Thank you to the suggestion of pulling out the tabs at the bottom of the sockets, some strange reason all my lights went out, i put in all new lights and nothing-pulled out the tabs on each one and they work fine
Posted on Mar 06, 2011
I also replaced the light switch and was getting ready to replace the socket when I saw the post to bend the tab in the socket out. Tried that and it worked!
Posted on Nov 09, 2012
I had same issue, replaced with known good bulbs, no luck...bought and installed new switch, no luck (old one was fine)...starting to worry about some board going bad, as the fridge is 21 yrs old. Read on here about the "tab" and pulling it up some. I thought, that's too simple, but IT WORKED!! Should had tried that before I bought the $20 switch. Always leaning..thanks to those who suggested the tab. Bob R, Georgetown, TX
Posted on Aug 30, 2012
    New Friend:
Tried this on my old 1970s sears coldspot and it worked!! Woohoo!
Posted on Jun 13, 2015
I am having a problem with my ref..it functions okay, but theres no light when i am open the ref.. before it does... whats wrong with it??? anyone help me what to do???
Posted on Jun 12, 2008
Refrigerator light not working,alreadyreplaced switch
Did you check the bulb? Those filaments do wear out and open necessitating the installation of another smaller appliance bulb. If a new working bulb also does not work, confirm that the socket is receiving power from the light switch you replaced..
Mar 20, 2015 | GE Refrigerators
Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later,
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
Nov 16, 2014 | Kenmore Refrigerators
Kenmore elite trio
The door switch that controls the lights is acting erratically. Replace it
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
Sep 23, 2017 | Refrigerators
How to change light bulb in ge refrigerator model gts18dbpalww
Unplug the refrigerator. For the refrigerator, unscrew the old bulb or bulbs and screw in a new appliance bulb of equal or lower wattage. For the freezer compartment, if a lamp is present, squeeze the top and bottom of the cover together then unscrew the bulb. Then screw in a new appliance bulb of the same wattage and replace the cover.
Note the appliance bulb is an incandescent bulb and may be hot.
The manual is available here: http://www.managemylife.com/mmh/owner_manuals/5791/GE-Top-Mount-Refrigerator-L0307014?brand_name_search=gts18dbpalww+ . The lamp replacement is given on page 13.
I hope this helps.
Feb 14, 2011 | GE Refrigerators
How to change a bulb in the Kenmore refrigerator
Most likely, you never notice the light bulb in your freezer or refrigerator until it is not working. Then it is time to replace the bulb. This is especially important with freezers, which are often in areas with poorer lighting, like basements or garages. Fortunately, the task is a simple one.
Instructions
1 Unplug the freezer to prevent an accidental shock when you remove the light bulb.
  • 2 Open the door of the freezer, look at the top inside edge of the freezer, below the door seal and back about 1 to 2 inches from the edge. You will see a small plastic or metal panel that protects the bulb from damage and shields your eyes from the direct light of the bulb when the door is opened. Reach behind the guard and remove the bulb by twisting it to the left.
  • 3 Put your new bulb in by inserting it into the socket and twisting it to the right to screw it in. Be sure you use a freezer bulb--it is built a little tougher and is the correct wattage. You can find them at appliance or hardware stores. Plug the freezer back in to test operation of the bulb.
  • Have a nice day! : ))
    Jan 30, 2011 | Kenmore Refrigerators
    How to change light bulb in refrigerator
    Unplug the Whirlpool refrigerator from the electrical outlet.
    Step 2
    Locate the bulb on the inside of the Whirlpool refrigerator.
    Step 3
    Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
    Step 4
    Unscrew the old light bulb.
    Step 5
    Screw in the new light bulb.
    Step 6
    Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
    Also note that the below can also work
    Unplug refrigerator or disconnect power.
    Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
    Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
    Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
    NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
    Plug in refrigerator or reconnect power.
    To change the freezer light bulb:
    NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
    The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
    Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
    Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
    Good luck in applying the solution
    Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
    Dispenser light very dim
    Put a new York Bulb for your tired computer. Sorry! Can't answer this.
    Aug 31, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
    Light bulb
    Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
    Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
    Refrigerators Logo
    11,052 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Marvin
    Marvin
