Hello, Sorry to hear you are having problems. According to the model number you provided, I found a manual you can download in pdf which has a troubleshooting section on page 21 which gives you a few things to check and try. If this is not the product you have and is an electrical dryer, then the heating coil has gone out. If this is your product and nothing you have tried in the manual works, then the problem could be related to a clogged gas port or a sensor/valve that adjusts the gas flow. I hope this helps solve your problem.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if...
(More)
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if these are good models or if there is any problems with them. Thanks...Jan
I have an old gas kenmore dryer that works fine except when you turn the dial to the timed section...
(More)
I have an old gas kenmore dryer that works fine except when you turn the dial to the timed section the dryer will not turn off by itself. I just replaced the timer control unit part # 693993 and the problem still exists. Any suggestions?
