Question about Canon ZR500 Mini DV Digital Camcorder
Power Switch intermittant when recording
I love my ZR500, but the power switch has developed a problem where it will sometimes power off and on multiple time before it finally decides it will behave. It only does this on the Camera setting, the Play setting is solid. Is there an easy way to get in there and clean the switch? I suspect a dirty contact, or some other fairly simple problem and it's off warranty.
  • Gary Oyer
    Gary Oyer Jan 24, 2008
    Have the same problem in the camera mode. If you touch or tap wrong around the main power/Play/Camera switch, it will either pause or power down. Is a switch problem economical to repair on cheaper cameras like this?
    I just email Canon on this question, I'll see what they say
  • DigitalDan Jan 24, 2008
    For that kind of money, I'd buy a new camera and get the warranty, etc. I'll live with it for now, until it becomes unbearable.
    Thanks for the info.
Since canon wants to charge more to fix it than what it is worth I would suggest buying another camera, just don't buy a Canon. Then I would take the piece of junk you are stuck with and send it to them. Tell them you will never buy any other canon products and then mention where they can stick their service dept.
Posted on Jun 21, 2012
  • Gene Jun 21, 2012
I got a response back from Canon. They said
"The repair cost could cost from $145 to $320. It could be more or less. The repair is based on the evaluation of the issue and the parts it will take to repair the camera."
For a $250 camera that wouldn't be smart.
Posted on Jan 24, 2008
Why does it switch on and off intermittently?
Check the power supply circuit for bad capacitors, you can tell which are bad by their bulging tops.
May 15, 2015 | Samsung Televison & Video
Wiper switch on my '97 Suburban will not work. Sometimes works intermittently. Any Ideas?
Not without testing the circuit.
Could be the switch or a wiring issue, or the wiper motor or the power source. Could also be the delay circuit board.
Oct 02, 2012 | 1997 Chevrolet Suburban
My Heritage II just lost power in the middle of vacuuming. The switch will turn on but no power.??? What is wrong?
It could be the switch that has become defective (the 'feel' of the switch may be different, but needs to be checked with a meter). Another possibility is that the cord has developed a loose connection at or near the power plug. Turn the switch on and wiggle/push the cord near the plug. An intermittent connection is indicated by the motor turning on and off. If so, cut the plug from the cord (they are usually a molded device that can't be serviced) and install a replacement plug from a hardware store or home center. If the switch is determined to be bad, order a new one from an appliance parts store or vacuum repair center. Good luck!
Feb 20, 2010 | Kirby Heritage II Vacuum
IMovie and Canon ZR500 no image
I have a slightly different but related model of Canon camera. I have found that if you erroneously power it on in "camera" mode instead of "playback" mode, you get the symptoms you describe: you can control the camera with iMovie, but you can't get any video out of it. Make sure you have the power switch in "playback" position -- it's an easy mistake to make.
Nov 12, 2009 | Apple Power Mac G5 Desktop
Sometimes power switch does not turn on washer
Which power switch.......the wall.........or the machine?
If the machine then the switch is intermittent and must be replaced. You can check the wall outlet with another appliance such as a bedside lamp.
Oct 20, 2009 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
I need to import video from my canon zr500 to my pc
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | Canon ZR500 Mini DV Digital Camcorder
When ever the ZR500 is shaken, it turns off.
I think that when you shake it, the battery tends to move around and makes the camera lose power and when you stop shaking the battery settles and runs normally.
Mar 15, 2008 | Canon ZR500 Mini DV Digital Camcorder
Power goes on and off when first turned on
the function switch of your camera is already losing contact that's why is intermitted on and off...when cleaning the function switch use a pencil eraser not a sand paper to the contact of the switch it will damage the switch...sometimes the flex wire of the function switch is been cut ...when you press the record button it is affecting the power
Jan 29, 2008 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony Handycam PC101E Record button/power switch...
there are loose connection of the power switch try to clean the contact of the switch and adjust it...use a pencil eraser only do not use any spray and liquid.....if you cannot put it back don not try open the camera....better go to the qualified and service center....
Aug 10, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Canon ZR500 Mini DV Digital Camcorder Logo
93 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
