Question about Brother LS-2125 Mechanical Sewing Machine
Thread wadding up in machine
I've had my machine for about two months without a problem. Lately I've been sewing and it's been fine, and then the thread starts wadding up. I've tried un-threading and re-threading it and the whole problem just starts again. I don't know what to do. Can someone help me?
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Sewing Machine (brother XL 3200)
Your machine is out of time and needs to be serviced by a technician.
Posted on Jul 19, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
Posted on Sep 22, 2008
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
  • 9 Answers
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 30 Answers
SOURCE: I own a husqvarna emerald 116 sewing machine, and
is the bobbin thread in correctly( meaning is the bobbin thread in the lower tension) if it is and the top thread is in correctly and make sure the feeddogs are in the up position if all of these factors are alright then it will have to go to a local dealer to get taken care of
Posted on Oct 28, 2009
0 characters
1 Points
Husqvarna classica 105 - won't sew - thread wads up in bobbin area
this is a problem from the needle thread tension not tight enough
tighten the thread tension right up
Aug 08, 2016 | Husqvarna Sewing Machines
Why is the thread catching on the tension discs on my Singer 5430C machine
Have you cleaned your discs lately? Thread has wax applied to it believe it or not. Take a sturdy piece of cloth, fold it over and "floss" the tension discs. Test the stitch again. If that does not solve your problem, then the discs themselves may need replaced.
Aug 24, 2012 | Sewing Machines
Machine is sewing along just fine and then makes a wad of thread on the underside and stops sewing. I removed the plates and cleaned out but it is still doing that. Seems to pull the top thread and...
More than likely it is your top threading that is not right. Try seating the thread in the tension discs. To do this, rethread, now with the presser foot up, pull the thread, it should feed smoothly. 'After this, put the presser foot down, it should barely move. Hope this helps.
Nov 14, 2010 | Kenmore 19365 Computerized Sewing Machine
14SH654: Singer 247 Machine runs fine and then bottom bobbi...
Try using a style 60 or 66 bobbin. I had the same problem at first, and someone on-line suggested the different bobbin. I use a style 66; instead of having a flat bottom and top (and all those holes), it's shaped something like a bagel. Now my machine works beautifully.
May 16, 2010 | Singer 14SH654
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Sep 30, 2009 | Bernina 1008
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
Apr 24, 2009 | Kenmore 16622 Mechanical Sewing Machine
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
I hope this helps!
Happy sewing!
Sep 30, 2008 | Brother LS-1217 Mechanical Sewing Machine
Thread wadding up
Tension!!!! Its all about the tension! I just had this issue after loosening my tension. So tighten it - the higher the number the tighter the tension. My tension is set at 6 on a Singer 9005 and it seems to work great. By turning it down to 4 I ended up with huge loops/wads of string. Hope this helps!
Nov 03, 2007 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
52 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
