Question about ASUS A8V-E Deluxe Motherboard
Major help needed
Hi, I have recently replaced my my mother board, processor, video card, and power supply in my computer. My pc started fine and I began installing all of my drivers. after 4 minutes my computer rebooted on its own. I then started installing my drivers again. 4 min. later same thing. after numerous repeated attempts my pc now will not even let me enter the bios. It freezes and will not enter the bios or any other program. I have also made repated attempts to reset my motherboard by following the instructions that came with the motherboard, still no avail. any help would be greatly appreciated.
    Novelist:
    Scholar:
  • 136 Answers
Hi jtiker,
if you have replaced all the parts mentioned above then you will need to reinstall windows as it will try to use drivers from the old windows and create more problems for you.
go to the bios and set it to boot from the dvdrom first then reinstall windows.
your only other choice is to boot in safe mode and try to reinstall the mobo drivers....not recommended though
good luck
smeags
Posted on Jan 02, 2008
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
What mother board fit the Sony VAIO VGX-XL2
A micro ATX or mATC motherboard will not fit any Sony VAIO VGX-XL* model HTPC. These systems have a non-standard form factor, proprietary motherboard built for Sony by ASUStek (based on their ASUS P5 boards).
Micro ATX or mATX boards do not match the mounting screw pattern, and the case and rear panel would require major modifications (and many internal components removed and not reinstalled) for any replacement motherboard. The Power Supplty is also non-standard 18-pin version of an ITX low profile model power supply.
There are a few upgrades which can be made to a stock XL2 (up to 4GB RAM, better low-profile video/graphics card, DVD optical drive replacement with Blu-ray, a SSD system OS/BOOT drive), but the motherboard, power supply, BIOS and and OEM Pentium D processor cannot be upgraded (because of a locked BIOS microcode). The XL3 model offers a few more opportunities for upgrade (up to 8GB RAM, upgradeable Core2 Duo processor options) but the rest of the restrictions apply (motherboard, power supply not upgradeable).
Apr 09, 2010 | Sony VAIO VGX-XL2 Digital Living System PC...
Emachines T3958 will not turn on
Check the fuse on the inside of it and see if it is not blown, if not blown change it any way it may not look like it is blown but it is hard to tell, and see if that work.
Jul 10, 2009 | E-Machines eMachines Refurbished EMA...
My computer's Video automatically shuts down after 3 mins. being turned on but all the fans are still working. what could be the possible problem?! pls!! help me!! below here is my specs: Motherboard - IBM...
hi! there,
there are possible causes of tripping off your windows,mostly parts by parts are being tested to assure that part is malfunctioning,since fans are working means power supply are fine,but there are multi terminals that are supplying your power supply.loose power trrminal could be one of causes.lets not concentrate on that,may be in the future.
your pc is p3 and has a higher device capacity w/c upgraded to increase capability and
could acquire in internet speed and other software
your processor is 996 mhz,some software specially on gaming at this time has a higher processor system requirement w/c ranging to 2.4gb up to 3gb and more.why did you not acquired a higher mother board suitable on your device 2.4gb is fine,well 3gb is much better.
since the problem is after 3 minutes your windows turn to black,three main factors we can consider video card,ram and processor.switch off your pc, try to disconnect cd room,hardisk and floopy.then switch on your pc will still run on start menu. wait of more than 10 min. if still trip off.if not, it's fine your hardisk or cd room is problem
if trip off again,in this case you should have a good extra ram and video card that you know is working,replace and connect the spare,switch on
here we can know w/c parts is busted, if not run in good,*********** board is defective,if run your video card and ram,one of them is defective.so isolate cheking to assure.
if you got the part is defective you replace and put back all parts and switch it on.So you have done it all alone you can be technician somehow.take necessary precaution doing this
this shoul be done by qualified technician.
if mother board i doubt it is due to has a low capacity.beside this should be replace in order you to enjoy using your pc your device capacity is fine.it does not much on p3.cheers and have a nice day,what about my rate don't forget about that, thanks
Apr 08, 2009 | IBM NetVista A40 PC Desktop
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
No boot or beeps
clea your processor and then refix it.then alsom check with other ram may be your ram is faulty.also some times earthing problem creates problem in booting proces.
Dec 29, 2008 | Computers & Internet
Installed new Power supply, Monitor stays in standby...? So I noticed my fan was starting to go out, then it actually went out, my power supply would start to over heat and the cpu would shut itself...
Your problem is either the processor or the motherboard. that is why your monitor is not getting any signal. first try to replace the processor because I suspect that this might be the problem as it has gotten overheated before. if there was a power problem with you power supply you monitor would not power up at all.
Jul 10, 2008 | Computers & Internet
Ihave a emachines modelT2792 and have een told the mother board is no good as well as the power supplycan i get another mother board for this computer or is it too old to fix it is about 2 years old
when all some other parts are good maybe you can replace the the mother board and the power supply.
you should find motherboard replacement that will fit to your processor and Memory.
if the memory , processor, hard drive are good, then you can contact your vendor if the have replacement(mother board) and power supply.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 15, 2008 | Computers & Internet
Power problems with Dell Dimension 4600
Your mohterboard seems to be bad! If you have replaced the power supply and placed all connections in the rightful place, with no result! Your Motherboard is definetly bad!
Nov 29, 2007 | Dell Dimension 4600 PC Desktop
P4MBMS Motherboard Problem
look for the reset jumper on the board and then reset it then try again
Jun 03, 2007 | Mach Speed P4MBMS Motherboard
ASUS A8V-E Deluxe Motherboard Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
