Page fault in nonpaged area a blue screen pops tech info stop: 0x00000650(0xF43B8BE7,0x00000001,0x80D6F6A9,0x00000002 this is a dellinspiron laptop model no.PP22X with windows vista
Restart the Computer and keep tapping the F8 key for 5 to 7 seconds to display the Advanced Boot Option screen. On that screen, select "Last Known Good Configuration" option. Furthermore, if you've installed any new hardware then uninstall it.
Once the Computer is able to boot successfully, run "chkdsk /f /r" utility to detect and repair any disk errors.
Faulty hardware, a buggy system service, anti-virus software, and a corrupted NTFS volume can all generate this type of error.
Disconnect any newly added hardware (all those unnecessay USB harware) and reboot. If that does not work, use another computer to access and query the Microsoft Knowledge base. You will find what the meaning of the different numbers in your message.
Hope it helps.
Basically this indicates the windows page file is trying to write to a non-paged area. Some common causes of this are a software that is trying to access a memory area it is not allowed to, a bad memory, defective hard drive sectors or too small of a page file. If you have recently installed some software, try removing it. Badly written software often conflicts with operating system drivers causing page fault. Try shutting it off and removing and replacing the memory, a poorly seated memory socket will cause a error. Right click your hard disc properties and run checkdisc- with all options selected, requires a reboot , and then run defrag. Possibly also running some 32 bit programs or drivers on a 64 bit system will also cause that type of error.
