Question about Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
Ariston FO98P Stainless Steel Electric Single Oven >
Hi. the code error FSE2 has appeared and the oven turns off immediately after turning it on. i do not seem to be able to find my manual.what is the problem?? although the oven is approx 4 years old it has only been in use for 6 months.
  • 3463 Answers
SOURCE: Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Posted on Jan 17, 2009
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
  • 160 Answers
SOURCE: stainless steel single oven type FCSM6
If the fan is still operating then its the Element that needs replacing..
Posted on Dec 21, 2009
SOURCE: Cata Single Oven Stainless Steel EF60SS Can't get it to heat up
Hi Ya
I have the same oven with the same problem.
To resolve the problem you will need to replace thermal switch, which can be found at the rear of the cooker behind the protective cover. Approx at the bottom left corner. It looks like the shape of an eye with to wires. Hope this helps. Kevin Reseigh
Posted on Jan 18, 2010
  • 43501 Answers
SOURCE: Smeg f67 electric oven not reaching temp on conventional setting
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
Posted on Apr 23, 2010
0 characters
1 Points
Hi my Ariston oven shows in the display error 07. I have an ariston oven FZ 87.1 (IX)
problem je v nedostatku vzduchu pri ventilatori,treba viac priestoru pre ruru
problem is the lack of air when fan, need more space for tube
Jun 29, 2011 | Ariston Technologies Ariston FO98P...
We just purchased a new ariston oven but there is no grilling tray. Were we supposed to buy the tray separate?
It should have been suplied with a grill tray of some description, go back to who supplied it for you, and ask them for one.
Aug 14, 2010 | Ariston Technologies Ariston FO98P...
We do not get a clicking noise to light the oven like we do the burners. We can't get the oven to light
if the oven is electric start, you will not hear a clicking. more than likely it is the oven igniter going bad. be very carefull if you change it yourself, they are very fragile. hold on to base if possible.
Apr 02, 2010 | Ariston Technologies Ariston FO98P...
Ariston oven fm51ix
new knob req Email model no and seriel no we can supply parts. regwoolley@uwclub.nwt
Jun 11, 2009 | Ariston Technologies Ariston FO98P...
Marking have worn off on front cover of ariston FM 22 M IX - oven
Try using - I recently had same problem the symbols are easy to apply and look great. A brand new oven in minutes, speak to Mark - he can guide you through the process - very helpful
Mick Lawry
May 17, 2009 | Ariston Technologies Ariston FO98P...
Ariston dishwasher
I have the same problem. I found that a termostatic probe switch off the machine, you can disassemble the door and clean the ventilation holes
Aug 31, 2008 | Ariston Technologies Ariston FO98P...
Control panel
generaly the only way to reset is by turning off the power to the oven at switch board for at least 30s. if this does not work check the back of the digital panal for any burn marks as it may have shorted when it fell back, also check any wiring connectors have not come off
Feb 18, 2008 | Ariston Technologies Ariston FO98P...
Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven Logo
186 people viewed this question
Top Ariston Technologies Ovens Experts
Dan Webster
Dan Webster
Jason Harris
Jason Harris
Andrew Taylor
Andrew Taylor
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
