Question about Kenmore 80412 Microwave Oven
Danby micro: turns, lights, doesn't heat
It heated milk for 30 minutes last night, then did not heat at all this morning.
  • Kenmore Master
  • 9,098 Answers
Heating for that long may have damaged the magnetron.
I would suggest you contact Danb for assistance:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 06, 2007
I made popcorn last night and my microwave worked perfectly. This morning it will not heat a cup of coffee. What's up with that? What can I do to fix it. It is part of a matching set. Kitchenaid micro over...
When unplugging it for half a minute or so (this should reset all settings) won't help, it must be defect. When you are convinced you did press the right buttons and you are in the correct program you don't need to unplug. But for that you have to be sure it is not switched to oven. In 30 seconds it won't be warm enough to heat your coffee
Mar 10, 2015 | KitchenAid Microwave Ovens
Microwave stopped working. No power
please follow this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_4_57_51_pm.gif
Jan 24, 2013 | Panasonic NN-S541 Microwave Oven
Microwive not heatin
Ufortunately the magnetron is the most likely problem, "heats food" and is the heart of the microwave oven. If the device is five years old or more cheaper to replace the item.
Mar 04, 2012 | Sharp Microwave Ovens
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @
Aug 06, 2011 | Microwave Ovens
My oven heated fine 2 days ago and the kids tried to heat some sandwichs last night and it didnt heat. The table turns, clock counted down and power setting on level 10. I boiled water this morning to...
after several reviews of this microwave i have found that most people are not satisfied with the model or the company. And that it seems that your problem may consist with the magnetron not being installed correctly sometimes this happens at the factory but can only be replaced by a technician. they are supposed to carry them on their truck at all times. Youll have to call GE and schedule an appt with a tech. and from other testimonies that can prove to be difficult. sorry i couldnt have been of more help and good luck
Jan 25, 2011 | GE JVM1850 1000 Watts Microwave Oven
The microwave shuts off after 10 minutes and takes 30 minutes to come back on. Help!!!
It indicates the magnetron is getting to hot "that heats the food" when that happens the thermal fuse opens to protect the magnetron from over heating and shuts it down and waits until it is cooler before it resets. The other problem could be the fan not working or not properly that blows on the magnetron, it helps keeps the temperature regulated so it can run hard. If it turns out the fan is fine, then the magnetron is slowly breaking down until it becomes unusable, which means it will need to be replaced "pricey" or buy new "probably cheaper"
Jan 20, 2011 | Danby DMW139 Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Installed a new hmw9305 last nite, no power
Sounds like you blew the fuse. I have a tip at which explains the problem, how to correct it and where to get any parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Bosch HMV9305 Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Kenmore 80412 Microwave Oven Logo
1,521 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
