Question about Candy CN146 Front Load Washer
Candy cmd146 washer dryer
Could you please tell me why my washer dryer is not spining.
  • dragana Dec 07, 2007
    it draines but does not spin so clothes are full of water at the end of program
  • Anonymous Mar 18, 2014
    Water doesn't drain
    Champion:
  • 249 Answers
More info. i.e is it pumping out water????
Posted on Dec 05, 2007
  • eamonn close Dec 08, 2007
    could be the speed control module, or pcb board,also check pressure switch.ie.water level switch to test it dis connect small hose going to it,then try spin only,and see,good luck.
Belt for CMD146
you will need to replace the brushes in the moter ok
Oct 18, 2012 | Candy CN146 Front Load Washer
Cmd146 dryer heating top chamber but not in drum
It sounds as though the fan motor is faulty, usually these motors distribute the heat from the heater box into the drum. Because the heater box is getting hot I doubt if the fault is the thermostat so it may well be the motor or associated wiring
Mar 29, 2017 | Candy CN146 Front Load Washer
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
Instruction manual required for candy smart cmd146
How do u turn the heat down when drying clothes?
Jan 12, 2011 | Candy Washing Machines
Machine candy washer dryer cmd146 will not start after repeating pushing the start button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Mar 18, 2010 | Candy CN146 Front Load Washer
Need a User Manual for Candy CMD146 Type LCE2
Hello.
I can direct you to the site you need to download a copy of user instructions for your washer dryer.
In your browser bar, type -
hoover user manuals
In the drop down list, click on-
hoover after sales service-instruction manuals
Then click on -------laundry
then click on --------washer dryers
In the box enter your model, and you can download the instructions.
Pleas a fixya rating for my solution to your query..
Thankyou.
Jan 30, 2009 | Candy CNW156 Front Load Washer / Dryer
Candy CMD146 Washer Dryer drum spins but does not heat
Yes it could be the heating element. However, it could be the thermal overload switch. This is located under the top of the machine. Bypass it to see if works. If it does, then it is the switch. If not, check the element. It sounds like this is the element with the 2 yellow wires.You will need to pull it to visually check to see if it is burned in 2.Check the element first since you have easier access to it. Let me know how this works.
Jan 27, 2009 | Candy Dryers
Washer/dryer problems
If you can locate the filter, remove and clean it.
They are usually found at the bottom front, behind a removable plastic panel.
Plz rate my solution,
Thanks.
Jan 13, 2009 | Candy CNW136 Front Load Washer/Dryer
Candy CMD146 Washer/Dryer
Is the dryer electric or gas? If electric, the heating coil may have burnt out. If gas, check gas supply and then gas ignitor. Good luck.
Jan 28, 2008 | Dryers
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
Candy CN146 Front Load Washer Logo
628 people viewed this question
Top Candy Washing Machines Experts
Marvin
Marvin
shaun taylor
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
