Question about Brother HL-2070N Laser Printer
Every time I try to print it tells me that the printer is off line
How do I get the printer ON Line so that I can print out my pages?
Trying to setup wireless print on my brother 2070N
Posted on Dec 15, 2007
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
HP Officejet Pro 8500 Printer does not print the last line
Try uninstalling the driver and reinstalling it by going to HP's web page. Before doing so, defragment your C drive.
Oct 22, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
When I print I only get a line of garmage at the top of the page - i've tried rebooting, etc.
Have you printed a test page without it pluggetd to the computer? What did you get.
Try telling the computer it is a HP Laser jet II
Then print a test page, tell me what you get.
Only put a couple pieces of paper in it just incase it goes nuts.
Feb 12, 2010 | HP LaserJet 1300 Printer
6122 deskjet prints test page fine but only prints one line on the paper for all other print jobs.. what is wrong?
Is it almost a solid line? This may be an application problem. Are you printing text?
I have seen this in two flavors:
1) If there are switch settings for this printer you want to make sure that the printer is set for CR/LF ( Carrier Return/Line Feed). This tells the printer to Return the printhead to the start of the line and the LF command tells the printer to step up the page.
2) If you are connected serially, the parity bit may be set incorrectly. Depending on the parity,the bit could printer if set for even parity but the sending PC is set to EVEN parity can cause a LF command to get ignored and the symptom is the lines print on top of the first line.
Feb 05, 2010 | HP DeskJet 6122 InkJet Printer
Can't get my HP LaserJet 4MV to print. It printed yesterday but now it says "Printer not responding. The printer is on and I have checked all cables. Help
Can you perform a test print? Try this:
To print a Test Menu page
Press On Line] to take the printer off line.
2 Press [Menu] repeatedly until TEST MENU appears.
3 Press [Item] repeatedly until PS CONFIG PAGE (or another PS test page)
4 Press [Enter] to print the page. The page will print in less than one minute.
5 Press [On Line] to place the printer back on line.
Did the printer print? If so, you may have either an nterface or cable problem.
Oct 23, 2009 | Office Equipment & Supplies
Printed pages come out with dark lines under each line of print
Find your printer's "Maintenance" menu, in its "Toolbox" or from the Start Menu.
Preform a cartridge or head cleaning, that should solve your issue. If not, try replacing the cartridges with new ones.
Hope I helped,
Jun 21, 2009 | HP Photosmart C5280 Printer
Xerox Phaser 6250 yellow line at far left of page
Sounds like it is time to replace the imaging drum. This is a consumable and usually done every 15-20k pages. Cost is about $250-300 and very easily replaced, fast as changing a toner.
I am assuming that you tried changing the yellow toner already? If not, do that first...
Jun 18, 2009 | Xerox Phaser 6250DP Laser Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Printing on the same line after a few pages printed
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
May 30, 2008 | Epson LX-300+ II Matrix Printer
Brother HL-2070N Laser Printer Logo
70 people viewed this question
James Cagle
James Cagle
Jim Keysor
