Question about Brother MFC 7420 All-In-One Laser Printer
Scanner locked My printer give a message saying scanner locked and the car got stocked.
  • 45 Answers
Okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide :
11-3 is the scanner locked section
11-5 is the fax removal section
Posted on Dec 05, 2007
How do i fix the error on y printer that says scanner is locked samsung printer Xpress M2070FW
dear lydia
the scanner is may try with knocking lightly on your both palm at the top of platen cover. some time this releases the jam. if persists call trained person to re assembly the set.
Mar 05, 2015 | Samsung Xpress M2070FW Multifunction...
My scanner won't copy, all I get are black lines
Something could be electrical/mechanical mistimed now in a mechanical way dirty microswitches that have not give a break on the right moment to stop the scanner and has damaged something what has to made the loud noise .
Keep in mind your safety by working on high voltages and also mechanical recovery.
Aug 11, 2017 | Dell 1815dn All-In-One Laser Printer
Error light on and saying scanner error
Open the Lid for scanner, check for a switch on the side for Scanner Lock. Try to switch it to unlock position and retry booting up Printer. That should take care of scanner error message.
Hope this helps. Cheers!
Mar 04, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Please help... Says "scanner locked"
Power off the printer. There is a green tab located in the paper output section of the printer. If you side your hand below the keypad on the left side you will feel the tab sticking down. Pull the tab towards the front of the printer to unlock the scanner. Then power on the printer, this should remove the scanner locked message. Hope this helps you.
Jan 26, 2011 | Samsung CLX-3160 All-In-One Laser Printer
The error message is saying the scanner is locked i took the steps to unlock it but i still get the same message
If you opened the lid in the same manner as you would to replace the ink cartridges and made sure that the switch on the right side underneath the lid was in fact unlocked, turned off the unit, waited a moment (up to 60 seconds) and turned the unit back on, but still receive the message saying that your scanner is locked, then you will need to use a Phillips screwdriver to remove the top cover and make sure that the scanner head is not somehow jammed. Usually you can hear the gears and motor spin up when the scanner head is unlocked. If you cannot, you may have a bad scanner head.
Aug 03, 2010 | HP OfficeJet 9120 All-In-One InkJet...
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Scanner locked
Reach in the cavity where the paper comes out. In the top left far corder you will find a blue sliding switch. Pull it forward and press cancel.
Jul 23, 2008 | Dell 1600n All-In-One Laser Printer
Epson CX5400. I have 2 and both are giving 'error'red light and message 'scanner error' see documentation and caqll service if necessary'. I have rung an Epson Service centre and they say it is not...
Please follow the steps below to resolve your issue.
1. Turn off the printer.
2. Lift the scanner cover.
3. Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4. Turn on the printer, and the error should be cleared.
Update me if you are still getting the error message.
Apr 28, 2008 | Office Equipment & Supplies
Dell A940 - Unlock Scanner then press power
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Brother MFC 7420 All-In-One Laser Printer Logo
1,235 people viewed this question
James Cagle
James Cagle
Jim Keysor
