Question about Sony KV-35S42 35" TV
Timer light blinking
I shut off my sony KV-35S42 and tried to turn it back on all I get is a flashing timer light I un plugged it and let it sit 2 min and still got the same thing
  • orlbuddy Jun 14, 2008
    I have the same problem. No picture but there is sound. Timer light keeps blinking. Any help highly appreciated. Thanks!
    Problem Solver:
  • 4 Answers
POWER SUPPLY PROBLEM.YOU MUST HAVE SOMEONE REPLACE TWO TRANSISTORS,VARISTOR,FUSIBLE RESISTOR,4 CAPACITORS & HORIZONTAL OUTPUT TRANSISTOR & RESOLDER PINS ON HORIZONTAL DRIVER TRANSFORMER.GOOD LUCK.4TUNE
Posted on Jan 09, 2008
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Sony kv 35s42 sound but black screen and constantly blinking stand by/timer red light
Your vertical IC will need resoldering. If you can take this board out and inspect the pins under the vertical IC, you will see rings around the IC. This is a common problem for you model of TV. Hope this helps...show a few hands of support.
Dec 14, 2010 | Sony KV-35S42 35" TV
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony kv-35s42 no picture, good sound timer light flashing
Usually, the CRT is bad......re-juvenation is a temporary fix at best........try adjusting screen control on CRT socket module.
Only other possibility is solder pins of vertical output IC.
Mar 20, 2008 | Sony KV-35S42 35" TV
Blinking screen
Bad CRT...no repair.................................T.
Mar 11, 2008 | Sony KV-35S42 35" TV
Sony KV-35S42 35" TV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
