Need to adjust to adjust timing so that the needle does not hit the bobbin
If the needle misses the the hook but is still down when the rest of the bobbin Hits the needle, then it is a timing issue!
Loosen the 2 set screws behind the bobbin to adjust the timing so that the neddle is up when the wider part of bobbin holder comes by!
That isn't the timing. If the hook is hitting the needle the hook is too far left - or close to the needle. It's adjustable by loosening the set screw at the base of the hook and by gently tapping the hook away from the needle. You want the hook to be close enough to the needle to pick up the thread loop that's formed just as the needle bar is rising.
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Testimonial: "very helpful...thank you"
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
