HP Compaq FP5315  15" LCD Monitor
Problem for HP Compaq FP5315 (Black, Silver) 15" LCD Monitor
My monitor just went to a black screen and the
By lauramich320 on Aug 29, 2009
My monitor just went to a black screen and the green light on the front just blinks. I took it to Best Buy and they connected it to their power supply, but with the original cables, and it worked fine. Brought it home, hooked it up again, and it won't work again. I have an old monitor that I am using and I evem changed the plugs from the old monitor to the new one and it still won't work.
Comments:
Aug 29, 2009
- I removed the VGA cord and plugged the old monitor into the tower and it works fine. I also switchted the VGA cords between the old and the new monitor and the new monitor still would not come on. However, if the grpahics or video card has gone bad, would they have been able to get it to come on at Best Buy?
Solution #1
posted on Aug 29, 2009
Not Rated)
sams_trix
Rank: Wiz
Rating: 85%, 39 votes
blinking light is a sign of no signal, try to remove the VGA cord (blue) from the system unit while the green light is blinking,there must have a display, cable disconnected or no signal. if it does, the monitor is okay and your VGA driver/graphics card has cause the problem. If you can try with known good monitor , it can confirm a problem. That helps....
Comments:
Aug 30, 2009
- Is your new monitor when turned on without the system unit indicates no signal or cable disconnected? If didn't, your monitor has a problem.
On your reply you didn't state the result.
Was this helpful?
Yes
No
Solution #2
Not Rated)
seanpwright
Rank: Guru  HP Computer Hardware  Expert
Rating: 87%, 297 votes
Sounds like your video card has gone bad
Was this helpful?
Yes
No
Popular Solutions for HP Compaq FP5315 15" LCD
Questions and Unsolved Problems for HP Compaq FP5315 15" LCD
Do you recommend HP Compaq FP5315 (Black, Silver) 15" LCD Monitor?
Answer
Answer
Hi, i have the same problem. My brightness randomly changes, and a message comes up "Waiting... (More)
Answer
no volume on speakers, or not working at all.
Answer
it comes on and off will not come on all the way,i've chicked the power cord not that
Answer
I've just formated my computer and when i switch it on my Monitor comes clear then fades in... (More)
Answer
my compq nc4010 screen broke so im using the vga port on my tv the screen apeers during the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq FP5315 15" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
