Question about SanDisk Sansa e140 MP3 Player
SD storage size
Can you tell me please what is the maximum size sd card I can use on my sandisk sansa e140.
Thankyou
I have a e260 sansa and I'm wondering what is the maxium size of micro sd card that I can install in it. Thanks
The maximum size for microSD cards is 2GB. Any larger cards are actually microSDHC (the HC stands for High Capacity) and won't work in the e200.
Sep 09, 2010 | SanDisk Sansa e200 MP3 Player
SD card suddenly says write protected; wasn't before - how do I fix?
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
Jun 18, 2010 | SanDisk Sansa e140 MP3 Player
Micro SD Capacity
The e260 will not recognize any microSDHC cards. It will only use microSD cards, which are limited to a maximum of 2GB in size.
Apr 14, 2010 | SanDisk Sansa E280 MP3 Player
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Micro sd 4gb card problems.
Check the Sansa tutorials at http://www.sandisk.com/Retail/Default.aspx?CatID=1468
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
Cant use sd card
Test the SD card in another device, or even a PC to verify that it is working or even formatted. Also what size is the SD card/. Does your MP3 player support this size. Give us more info.
Feb 02, 2008 | Computers & Internet
San disk e130 mp3
Hi. The E100 series players (including your E130) can only support up to 2GB SD cards.
Apr 21, 2007 | SanDisk Sansa e130 MP3 Player
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
SanDisk Sansa e140 MP3 Player Logo
59 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
