Question about Xtant A2002 Car Audio Amplifier
Car stalling car stalls when in gear, uses alot of gas and has no power when pedal is accelerated. Had fuel and filter changed, used carberator cleaner. Changed spark plugs. what could it be?
  • pinkymw7707 Aug 28, 2008
    Nissan almera 1999 stalls when slowing down to almost stopping, when stopping and sometimes around corners. Re starts no problem most of the time but sometimes has to be turned of completely and retry a few times to start please help its driving me crazy. been in a garage for three days and they dont seem to know what to do and its had a diagnostics test yesterday.
  • 24 Answers
What kind of vehicle is it it sounds like your timing might be going out v/m/m/y get at me and you can take it to autozone,murrays,advance for free diagnostic check if check engine light is on give me more detail and i can help you
Posted on Mar 08, 2008
Your transmission needs ah check up
Posted on Feb 13, 2008
    Problem Solver:
  • 14 Answers
Bad chip
take to dealer and let them charge 1000 dollars to use code reader - that should be free
Posted on Dec 05, 2007
How do I fix this? I have this problem and I don't know what caused it. I would drive normally and the car seems fine. Then it starts to act up, and it wont accelerate when I give it gas. The RPM continues...
I tend to agree more with the last suggestion it seems like fuel is the problem. Would do the fuel filter and if no change check fuel pump pressure. If all checks out then would start looking at power (electrical).
Jul 24, 2014 | 2007 Honda Civic 1.8
Lexus SC430 Stalling Problem
Check the EVAP system canister purge valve, usually located on or near the canister itself which should be near the fuel tank. If the valve is clogged or stuck, it will cause excessive backpressure in the vapor return system, which sounds like what is happening here. Good luck, hope this helps.
Jul 15, 2013 | Cars & Trucks
1992 olds cutlass supreme wont accelerate when pushing the gas pedal
Check oil first, Low oil sensor will shut down if more than a quart low. Change fuel filter, could be fuel starvation, change the air filter. stopped up air filter will put MAF sensor out of range. PERFORM OBDII SCAN SOON.
May 19, 2017 | 1992 Oldsmobile Cutlass Supreme
Hesitates to accelerate and power loss
Did you check the fuel pressure before and after replacing the pump ?
Is the check engine light on ?
Jun 28, 2012 | 1996 Chevrolet Camaro
Car stalls pressing accelerator do not increase
is it fly by wire or does it have a throttle cable ,if fly by wire change the sensors on the pedal
Nov 20, 2009 | 2003 Mercedes-Benz C-Class
My 1992 Nissan Maxima is sputtering upon acceleration. It has 220,000 miles on it and it seems to mainly have this problem in first gear. And mostly happens shortly after starting the car. Ive done a basic...
92 max
I own a 92 max 370 kms runs good but one day just cuts out while doing about 30 km, I pull over i can start it no problem but when I touch the pedal to accelerate the car stalls out.
It got worse to the point of sputtering on the highway , sometimes i could keep it alive by working the pedal but others would slow down and stall out.
I have changed the fuel filter and plugs seemed to make it a bit better but still stalling. I ran it in my driveway for 10 mins on idle then it stalls out
Is this the fuel pump??
Jun 13, 2009 | 1992 Nissan Maxima
91 Mitsubishi Mighty Max stalls during acceleration
Try changing your fuel filter, like on all fuel injection and electronic ignition problems the shade tree has to use the process of elimination. This is one of the cheapest.
Dec 14, 2008 | 1990 Mitsubishi Mighty Max
Xtant A2002 Car Audio Amplifier Logo
100 people viewed this question
Top Xtant Car Audio & Video Experts
hoyzee1
Tom Chichester
FastHarley
FastHarley
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
