Back to:
Tags:
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool dishwasher not working (by 5 users)
posted by igsanders on Dec 05, 2007
I have a whirlpool dishwasher Modle GU63XTLQ0 SER # FP1801615. The Clean light flashes seven times and then pauses, and repeats. I am not able to cjoose a cycle and the machien is frozen. I have turned the power to the dishwasher fo an hour to hopefuly reset the machien, but it did nothing. I do not have the funds to get a survice person out, and would like to do this myself if possible.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by rfamigli, posted on Aug 31, 2008
I have the exact problem as ronmac had:
"My Whirlpool Gold displays a "2" when "Cancel" is pressed. The unit then goes into a 2-minute drain cycle at which time the 2 disappears. The only response that I can get from the washer is to press Cancel, at which point the unit again goes into the 2-minute drain cycle. No other cycles light up when pressed. Any suggestions?"
My only difference is the "air dry" light will come on if pressed also.
This happened once before and it asked for rinse fluid. I gave it some and it worked fine ever since. Today I had the same problem without the rinse fluid light. I added some anyway, but no change. HELP
Comment by rry72, posted on Jun 25, 2008
I am having same problem and dont know what to do. It is about 3 years old. How do I can reset the sytem back
Comment by oreo66, posted on Mar 31, 2008
Same issue as igsanders
I had just swapped my disher and had to hard wire it- had worked fine 6 washes ago then all of a sudden this 'blinking' clean light flashes- I to had also 'rebooted' to see if it would self-set- nope!- so I followed your instruction and 'BAM' - works! so thx for the info and saving me $$$
Comment by ronmac, posted on Dec 06, 2007
Clarification Request
by sbsteele03, posted on Sep 13, 2008
my dishwasher is doing the exact same thing -- the clean light blinks 7 times then pauses and repeats. have tryed unpluging and a few other things. can someone tell me what to do to fix this. any help would be apprieciated. thank you
Best Solution
posted on Feb 19, 2008
FixYa! (100)
modsoution
Rank:Apprentice Apprentice
Rating: 100%, 5 votes
appl_doctor solution # 1 is the fix worked for me. Thank you very much appl_doctor
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Whirlpool dishwasher not working:
I don't want to Accept this solution
Solution #2
posted on Feb 16, 2008
FixYa! (100)
appl_doctor
Rank:Guru Guru
Rating: 90%, 85 votes
igsanders.. that is a heater fault code. toggle between heated dry and normal until all light light up . press cancel. now ensure door closes without striking cabinet and the unit is level. this fault normally has nothing to do with the heater but rather the nuetral to the door switch which it shares with the heater.it will now operate again.
Thank You!
Can you Help with these Dishwashers problems?
Whirlpool Gold 24 in. Built-In Dishwasher...
When I turn the DW on it fills with water and seems to be...
Whirlpool dishwasher series DU600 3381181. Now Dishwasher...
I have a Whirlpool GU1200XTKQ0 that has a food chopper...
the clean light blinks 7 times pause and repeats the washe...
My Whirlpool Gold GU980SCGS3 keeps running after the cycle...
Loading problems.
Repair Service
Find Dishwasher Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
