Question about Logitech QuickCam Fusion Webcam
Driver Conflict ?
My computer has started to crash during loading up, when I disconnect the camera all is well. I have recently had an update to one of the google desktop products. I am running windows XP
    Genius:
  • 1,027 Answers
Download the version 11 software from this link.
Posted on Mar 26, 2008
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Aug 04, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Resource conflict-how do i resolve?
It appears you have a driver issue. What you can try is reinstalling them.. To do this just insert your main board cd and install the drivers of it..
If that fails remove the drivers and let windows axcess the generic drivers and then reinstall your drivers.
TO remove a driver , click start, right click computer
click properties then hardware then device manager
right click your devices to the let, the ones with the confilct, main board and wireless adapter , and choose uninstall..
another thing you can try
is downloading tune up utilities from www.phazeddl.com and running the registery scan..
If the above fails as a last resort , back up your data, format your harddrive and reinstall windows as well as your drivers and software. If after that the problem persist then a hardware device is defective ,, i'd say your wireless adapter thats why the system crashes when you run it.. Replace it..
let me know what happens
Jan 19, 2008 | Gateway MX6128 Notebook
I purchased a JVC BR-DV600U DV deck to use with my Mac computer for video editing. When I plugged the Firewire cord from the deck into the computer, problems began to happen. Two of my three external...
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
Feb 05, 2010 | JVC BR-DV600U Mini DV VCR
Computer will lock up after sitting idle for short period of time
This type of problem is usually a device driver conflict in my experience. Try updating drivers in your machine and see if it runs. If you can find your updated drivers quickly and load them, you might solve the problem without a lot of effort. Pay special attention to the video card driver because they are often a problem, particularly old drivers. Plan B is more time consuming. Detailed troubleshooting requires you to start the computer in "safe" and slowly add the drivers back in until you find the one causing all the trouble. Then you must either disable the driver or update it. You can also start disconnecting components (CD, DVD etc) and see if you can get you computer to run normally. Identifying components and associated drivers might solve the problem too. Hope this helps.
Mar 30, 2009 | Gateway Computers & Internet
New loud beep when volume control is adjusted
START- right click mouse on MY COMPUTER - PROPERTIES- HARDWARE - DEVICE MANAGER - SOUND VIDEO & GAME CONTROLERS -Right click(mine is realtek HD audio ) -PROPERTIES - ROLL BACK DRIVER.
Good Luck. Tom Smithbrother.
Dec 26, 2008 | Microsoft Windows XP Home Edition
DVD Burning Problem
To reinstall the driver RIGHT Click on My Computer - select Properties - select Device Manager - RIGHT Click the DVD listing - select Update Driver (have your disk handy).
Good luck.
Apr 19, 2008 | NEC ND-2500A DVD±RW Burner
Restart the computer
Just check to make sure that the CD-ROM drive has all its cords properly attatched. It sounds like there is either a driver conflict of some sort or a power failire in your system causing the BIOS to restart the machine. Check all power cables and if you recently updated the driver to the drive, roll it back. If your problem is still not sorted, try disconnecting the floppy drive or something from the mother board and power, see if the power supply is being overloaded. Or, you may need to simply purchase a new CD-ROM drive, would probabaly be your best bet.
Jan 05, 2008 | Computers & Internet
Antivirus failure
If you installed any program during this period or did any changes to the windows files, you might have caused a conflict that corrupted the anti virus files. Try uninstalling the antivirus and any recent installations and reinstalling the antivirus. Then update through the net update. Good luck.
Feb 21, 2006 | Symantec AntiVirus 10 with Groupware...
Logitech QuickCam Fusion Webcam Logo
41 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
