Question about Radio Communications
Radio transmission When I talk to others on radio I can hear them but they cannot hear me very well
    Brigadier General:
  • 6,966 Answers
Based on your post/description, you can hear others (RX-receive) OK but "...they cannot hear...very well..." then the problem is with the TX or transmit.
If the problem only is when the others are far from you, then it is possible that you have a defective final or at least a defective antenna/connector/solder joint. If on the other hand, the problem is present whether near or far, then perhaps your problem could be the modulation circuitry (which includes the mic). In some instances, it may be due to the Interference Elimination that you and/or your friends are using. At other times, it may be because of the battery no longer charging completely.
In any event, you would probably need the services of a qualified communications technician since this would involve opening the unit, familiarity with electronic components and circuitry, use of a DVM & a soldering iron or hot air blower.
You have to consider the cost or repair and the downtime. In most instances the cost of repair would just be a little lower compared to buying a new unit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
3 Suggested Answers
  • 1654 Answers
SOURCE: motorola t5100 cant hear the other person talking into the radio
Check to see you have the radios set to the same frequency and interference eliminator code as one another. This would be the most likely cause.
Here is a link to the owners manual
Posted on Sep 27, 2008
  • 1654 Answers
SOURCE: Can't hear each other when talking?
Here is a copy of the user manual: Double check the programming of your frequency and interference eliminator code.
Then you might check your Qt filter and your call tones. Set both to the zero (off) position and see if you have the same issue.
Posted on May 01, 2009
What do CTCSS and DCS means
CTCSS is a subaudio (<300Hz) tone that is broadcast when you transmit on a radio. If another radio is set to receive that tone, then the squelch will open and he will hear your transmission. Having said that, any other radio that does not have CTCSS set at all will also hear your transmission, so all it does is for the receiver to hear less of others talking. DCS is the same except that CTCSS sends out a continuous tone, DCS sends out a string of tones. This allows more "channels" to be allocated, but still ,everyone is using the same frequency
Jan 25, 2015 | Radio Communications
How to change the squelch on mtx8000
You can always have a radio receive. To transmit require an FCC License, and you need authorization to "Talk" to Public Safety. There are large fines and possible jail time to talk on channels you are not authorized for, especially Public Safety. Sadly, your radio is programmed to monitor only when the button is held down. The frequencies in your area working are a lucky coincidence. Take it to an Authorized Motorola Dealer and pay to have it reprogrammed. Radio is not field programmable. Hold onto your wallet, they are expensive to have programmed. You should have bought a high end digital scanner.
Aug 29, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
Lost the FM signal this morning, AM still works fine. all I get is static on FM with some intermittent what sounds like CB radio.
hello please check the rear of the radio as antenna could have come away from it hearing sounds like cb radio do you mean transmissions can you hear someone talking ,its probably someone near you that you are picking up
Mar 17, 2011 | Sony CDX-CA750X CD Player
When I depress the transmit button the cb puts a squel out to other radios on the same channel yet I have no problem hearing transmissions from the other radios
It sounds like the mic either has a problem, or its wired incorrectly for that radio.
Try a new mic, and make sure it's wired for that radio.
Also, if you have talk back then it's too loud, or your mic gain is too high.
The type of radio would help me know weather or not it could be the mic wiring.
Oct 20, 2010 | Radio Communications
See if the one radio that doesn't hear the other has a PL tone programmed into it. If both radios are not programmed to the same PL tone, then one will not hear the other. Consult your owner's manual on how to do this.
Jun 24, 2009 | Motorola Walkie Talkie 2-Way Radio
I can rx transmissions but they can't hear me.
Check the settings of both your interference code eliminator and your Qt filter (if your model has one). These codes need to match the other radios exactly. If the other radios have a Qt filter and your unit does not, then the Qt filter would need to be shut off on the other units.
Feb 11, 2009 | Motorola TalkAbout T5000 2-Way Radio
Has static and cannot hear transmission
sounds like it is off frequency and needs retuning
Nov 23, 2008 | Northwestern Bell 99141 2-Way Radio
Motorola t6500
You need to set your interference eliminator code to zero, and your Qt filter to zero also. Here is a link to the owners manual:
What is happening is your T6500 is set to ignore radios which do not match the same code. The fact your Cobras can hear the T6500 indicates they are set with their interference eliminator turned off (aka no code).
A similar occurance will happen if the Qt filter is set to anything but zero. The Qt filter is unique to Motorola. These features are beneficial when you are in a high radio traffic area and you want to block out hearing other people. But in your situation, you are mixing radios, and the easiest way to make them match is to turn off the special features (aka set them to zero).
Oct 17, 2008 | Motorola T6500 2 Pack Rechargeable 2-Way...
I can hear people talking, but they can't hear me, or they say I sound like an alien
Check to see if the meter needle is swinging backwards when you key up. If it does your final may be bad. If the needle goes forward and others say they see your keying up but no sound your audio chip may be bad; especially if you have tried so many mics and antennas. If your radio has a swr warning light and it comes on this could extremely limit your range and others may not hear you and contiued use will damage your radio. Good luck!!!
Jul 26, 2008 | Cobra 29 LTD CB Radio
Uniden Phone 5.8 Ghz- I hear a spanish radio station
depening on your location if you have no interuption from other freqency from other leaking environment you r hanset may have a manufacture sorftware or hardware problems if you try another hand set wiht same problem posible a decfive ..
Oct 01, 2007 | Uniden TRU8885 Cordless Phone
Radio Communications Logo
120 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
