Question about Samsung RS2630SH Side by Side Refrigerator
Fridge fan freezing
My fan keeps freezing after a couple of weeks since a complete defrost. is there a problem with the temperature control or is it the drain hole size?
  • 40 Answers
You may have a obstructed drain line
Posted on Dec 05, 2007
My Bosh Intelligent Frost Free 44 fridge keeps freezing up the pipe down the back of the fridge which keeps the fridge cool. We keep defrosting it by blowing hot air down to melt the ice and that wor
You can not get advice over the phone or here really
You need knowledgeable folks to be there & see the issue
It may not be getting enough air across the condenser coil to
remove the heat
It may have a refrigerant leak & is boiling off too soon & freezing
the evaporator coil
Or the other suggestions on fan control,switches & such
Dec 02, 2014 | Frost Refrigerators
Try rearranging all items inside fridge and freezer so that air may circulate around all items easily and then check seals on doors and ensure doors are closed completely and not leaking cold air. Also do a complete thaw/ defrost. You can remove the plastic coverings and ensure all ice is defrosted. Using a hair dryer will speed up thawing/defrosting process.
Nov 06, 2013 | Freezers
Hi, I have a Fisher and Paykel E402B Fridge/Freezer. It has not been working properly for a couple of months.. It does not cool/freeze properly. Through investigation I discovered that the coils and fan...
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Jun 21, 2011 | Fisher and Paykel Refrigerators
I have a 30 year old fridgidere top freezer refridgerator and the fan in the freezer keeps stopping first it sounds like it is hitting something then it stops and if I turn off the fridge for a day and...
This is a pure case of the AUTO DEFROST timer having a fault or the THERMOSTAT being weak.
The fan is hitting onthe frost that is building up after a couple of days.When you shut the fridge all frost goes off to clear the fan , the frost then build up gradually as the timer does not activate the auto defrost or the thermostat is cutting off the fridge as it runs on.
So get these two parts checked and changed. Inthe first place ccheck the timerr, normally at the rear bottom.
Sep 25, 2010 | Frigidaire Refrigerators
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Mar 09, 2010 | Refrigerators
Admrial LTF2112AR fridge not cooling
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 12, 2009 | Refrigerators
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Samsung RS21w USA style frige freezer panel problem
hold down the 2 lower buttons for 5 seconds to unlock the display panel
Sep 06, 2007 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
142 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
