Question about Apple iPod nano
I pod scroll not workn
I tried toggle the hold button then hold the center select button,to no vail. It doesn't even turn on when i touch it. thanks man
    Problem Solver:
  • 15 Answers
Do the hold button thing, then hold the center and play button together at the same time for about 10 seconds, it might not work the first time you have to try it atleast 3 times. if it still doesn't work, hook it up to the comp and leave it for a few hours, it might just be that the battery's dead.
Posted on Mar 04, 2008
How do i reset my nano
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Oct 07, 2013 | Apple Earphone Headphone for i Pod iPhone...
Trying to swicth off my i pod
Slide the Hold button on the top of the iPod so no red mark is visible. Press the main menu button until you see a long list of options (Artists Albums Songs Extras......) use the scroll wheel to find the sleep press and hold the center button in or Locate the Play/Pause button on the iPod. The Play/Pause button is at the bottom of the wheel around the select button. Press and hold the Play/Pause button until the unit powers off, about three to five seconds. Press any button on the iPod to turn the power on.
Feb 03, 2013 | Apple iPod MA446LL/A MP3 Player
I have a apple ipod A1199 my little brother got a hold of it now its in some forien language that i cant read how do i get the menue to read american again?
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Feb 28, 2011 | Apple iPod Photo MP3 Player
I plug my i pod touch 3rg gen. intothe computer and it stays connected for about 15 seconds then disconnects... its not the cord i used multiple... and it charges fine on a wall charger... help!!??!!
try resetting ipod.
To reset your iPod:
· 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
· 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
· If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
· If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 01, 2011 | Computers & Internet
I pod is blocked, everything seemed to be normal and now its stuck on playlist nothing seems to work, screen is alight though
Your iPod needs to be reset. 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Aug 02, 2010 | Apple iPod nano
'disc mode'displayed in window, large tick and o.k to disconnect. machine will not respond.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If for any reason this does not resolve your disc mode/frozen iPod issue please do let me know and remember to rate :)
Mel
May 20, 2009 | Apple iPod nano
My i pod wheel has frozen. None of the buttons work on my Ipod only the hold button when it is slides across causing the screen to light up. The i pod is 60gb and has not been dropped or exposed to...
That should get rid of the freeze.
If your unproperly disconnecting the ipod from your computer before the itunes
sofware disconnects it for you, then that could be your problem with the freeze ups.
Oct 23, 2008 | Computers & Internet
I Pod 4 Gb
Just charge the battery until the indicator says the battery is full.
well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 18, 2008 | Apple iPod nano
I pod freezes after initial start up
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Apple ipod
  • iPod classic
  • iPod nano
  • iPod mini
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
18 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
