I have a Maytag Neptune top load washer. When I attempt to start a cycle, a code appears (od) on the control panel followed by three beeps and will not operate. I've attempted to follow the procedure in the instrctions manual with no luck. Can you help?
I’m and owner as you and will toss out this info. The OD alarm means the FAV6800AW/FAV9800AW Control Board has not sensed a lid open condition for three completed wash cycles.You can unplug the washer 120VAC power and plug back in and see if that will give you three more wash cycle before extending the OD alarm again.This would only be a temp fix.You have probably lost Lid is Closed/Lid is Open signaling back to the Control Board from the Left Hand Lid Lock assembly. Take a look at this post and see if will help you repair the issue.I have some pic's and links in that post that may help.You will need the Service Manual for working on this machine. I use external magnets over the left lid bumper to accurate the magnetic operated reed relay switch located in the Left Hand Lid Lock assembly to check for signaling operation of that magnetic reed relay back to the Control Board.I’m going to start out by having you check out the Magnet Reed Relay signaling from the Left Hand Lid Lock assembly. With the Washer Lid open start a quick wash cycle, you should signal an OP alarm to the console do you?If so now close the washer lid the OP alarm should clear if the Lid Magnet is not out of position.If it doesn’t clear place couple magnets on the left bumper as I show in this post.If the OP alarm now clears then the lid magnet is out of position and the manual will show you its location to repair. If you still trigger an OD alarm then it’s time to inspect the Left Lid Lock Plug and assembly for corrosion issues.See Page 34 of the Service Manual.The technicians thumb is on the Left Hand Lid Lock assembly.The Left Hand Lid Lock assembly is not a sealed very well and is subject to corrosion issues with its location near the bleach dispenser.If you are a DIY’eryou won’t have any problem getting to the Left Hand Lid Lock assembly.The mating plug can be very difficult to remove from the assembly watch your knuckles.Be careful when you open the case halves of the Left Hand Lid lock assembly it is very easy to damage those retaining tabs.Unplug the 120VAC to your machine and follow the manual to raise the washer top from the base.If you have heavy corrosion issues you can clean up with contact cleaner ( I use WD-40) and some emery cloth/fine grit sandpaper.Check to see if the Black and Red wires are on the magnetic reed relay switch solder connections have not broken loose from corrosion.They can be re-soldered back on if they have broken loose.I don’t believe they have if you are not showing an OP alarm at the start of the wash cycle.You may want to squirt some WD-40 into the into the Left Hand Lid Lock plug and re-seat a few times if you have heavy corrosion in the Left Hand Lid Lock assembly as seen in the Pic. If you use a DVM/Ohm meter to check the magnetic reed relay switch make sure you unseat/pull the Left Hand Lid Lock Plug from the Left Hand Lid Lock assembly to isolate the signaling leads going back to the Control Board, we don’t want to kill the Control Board with the Ohm Meter. I would only break out the DVM if I had to start troubleshooting signaling back thru the wiring harness to the control boart inputs and +12VDC output to the Left Hand Lid Lock assembly. The Control Board would have to be isolated fom the Ohm Meter measurements. I recommend not using a DVM/Ohm meter at this point of the troubleshooting process. Here is a link for the Left Hand Lid Lock if you feel it would be easier to replace the assembly.Left Lid LockOther suppliers will have the part I like these folks. Post back if you have additional questions.
Rich
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Your suggestions were helpful because it allowed me to investigate the area in question and found the black wire had unraveled from the connection.
" - lousilvestro
Yes, on the Maytag Neptune the OP code indicates a problem at the door switch. These washers have a common problem associated with this code. The door isn't completely waterproof and allows water to get into the area where the lid switch is, corroding the electrical contacts and wires. Use a putty knife or screwdriver to open the top of the machine to access the door locks. Look for any broken or corroded wiring connections and reseat and clean as necessary. Test the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty switch. Sure hope this helped and best wishes.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
mine is a older maytag but heres my problem, on the bottom of the pump and in between the pully...
(More)
mine is a older maytag but heres my problem, on the bottom of the pump and in between the pully there is a thin circular peice of metal that keeps working its way up and grinding on the bottom of the washer. i can get it worked back down into the pulley housing but within a min it workes its way back out. besides that it seems to work fine ,is there any way to stop this from happening without buying a new pump. thanks for your time. .
The door does not lock and unlock thereby making it impossible for the washer to start when the...
(More)
The door does not lock and unlock thereby making it impossible for the washer to start when the button is pushed
The fabric softener and bleach do not dispense during a cycle. They remain full after the load is...
(More)
The fabric softener and bleach do not dispense during a cycle. They remain full after the load is complete.
