Question about Singer Featherweight 140Q
Singer 9W Treadle Machine
Would I be able to find the Bobbin slide plate, Standard sewing foot and Needle Clamp?
Kirsis
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
Rahul Sudhan
  • 30 Answers
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
Posted on Jan 05, 2009
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
How do I replace the slide plate on my Singer 416?
Lift the sewing machine pressure foot and make sure the needle is not in the way. Slide the plate under the foot control. Use a flat head screw driver to lift the spring back onto the plate then slide it back.
Jul 21, 2014 | Singer Sewing Machines
Ishow me how to rewind the bobbin on a touch tronic 2001 singer sewing machine
Presser foot up, takeup lever at the top, thread the machine normally all the way and through the needle, open the needle plate, press the little lever to the right, wind the thread from the needle round the presser foot screw, press on the foot control slowly and wind the bobbin, when you have enough thread on the bobbin close the slide plate the winder will drop down, pull the threads to the back of the machine and start sewing
Oct 30, 2013 | Sewing Machines
I need a manual for a singer touch and sew machine. It,s pretty old so i gope you can help me. I don,t know how to wind the bobbin. Help!!
Unlikely you will get a manual but here are the instructions.
Presser foot up, thread the top of the machine as normal all the way and through the needle, open slide plate, push the little button to the side and the winder will raise, take the thread from the needle and wind it round a few times round the screw that holds the presser foot on, gently press on the foot control and the needle will go up and down winding the bobbin, when you have enough thread on the bobbin close the slide plate and you will hear the winder drop down, pull the thread to the back of the machine and you are ready to sew
Sep 14, 2013 | Sewing Machines
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
How to fill a bobbin on singer sewing machine model 6268
Raise the presser foot and turn the hand wheel to put the needle at the highest position. Next open the slide plate by sliding it towards you. Make sure the bobbin is empty (remove any remaining thread or use a new bobbin). Slide the plate forward (partially closed) so that the arrow on the plate lines up with the arrow on the machine bed. Bring the thread from the needle under the presser foot and wind it around the presser foot screw (on the left of the assembly) once. Make sure that the thread is in the spring groove. Press the One-step Button hole A button (has a bobbin symbol by it). Then begin running the machine. Watch the winding process carefully and stop when you have enough thread on the bobbin. Do not let the thread continue to wind past the outermost line on the bobbin (black). Slide the plate fully closed and raise the needle. Pull the thread to the back of the machine to a length of 4" and cut the thread in the middle of the loop you just pulled through.
Now position your fabric under the presser foot, lower the presser foot and select your stitch. Begin sewing.
The manual is available for sale or download here: http://www.singerco.com/accessories/instruction-manuals/search . Just enter the model number. The direct link is: http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf . Pictures for winding the bobbin are on page 16 (page 18 of the PDF).
I hope this helps.
(make sure that the machine is correctly threaded before starting to wind a bobbin)
May 25, 2011 | Singer Sewing Machines
I have a Singer Touch and sew 600E and need to know how to thread the bobbin?
thread the machine up as normal, presser foot up,open the slide plate, push the button over to raise the winder, take the thread from the needle and wind it round a few times round the screw on the presser foot, press gently on the foot control and wind the bobbin, when you have enough thread close the slide plate and draw the threads to the back of the machine and away you go.
Jun 06, 2009 | Singer 3116 Simple
Singer 1060
slide open metal plate, there is a little white finger button with a target symbol on it just to the left. Slide this all the way left, leaving plate OPEN. If your top needle is threaded correctly, you should now be able to push the foot pedal to sew adn the bobbin will refill. make sure not to go past the outer white line on the bobbin case. good luck. the target button will go back to the original position when you slide the plate closed.
Aug 20, 2008 | Singer 1120 Mechanical Sewing Machine
Singer Featherweight 140Q Logo
157 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
