Question about HP PSC 1210 All-In-One InkJet Printer
Cannot print 8.5 X 14
Now that I've upgraded to VISTA, I cannot print on 8.5 X 14 paper. 8.5 X 14 shows up as an option in the page setup properties, but when I print everything is reduced in size and prints on 8.5 X 11.
Also, I upgraded to Office 2007 so I am not sure if it is a VISTA or Office problem.
  • Anonymous May 27, 2008
    i have done as directed you but problem is still there only a4 is printed when print with legal paper right sight get cut
  • Anonymous May 28, 2008
    cannot print legal paper size
How do I copy legal size paper on my canon Pixma MX49 printer
You should be able to change the printer page setup preferences before selecting the option to print.
When you have the document on the screen, go to "Print"...BUT before completing the option to print, look for the "Printer Properties" option and click on Properties......
Look for the option to change the page layout and find the option to change the paper size from Letter to Legal size paper.
Apr 28, 2016 | Canon PIXMA Office Equipment & Supplies
Print preview does not show full page
Go into the Page Setup for the email program that you are trying to print from and this should allow you to change the print settings.
For example, in Mozilla Thunderbird, if I go into File then Page Setup, on the Format & Options tab I get an option to Shrink to fit page width, plus can change the page orientation (Portrait or Landscape).
On the Margins & Header / Footer tab I get further options I can use to control how big the page margins are and what header and footer information gets printed, i.e. page title, page numbers etc.
Once you've changed the Page Setup values, see what has changed for you on the Print Preview
Dec 23, 2011 | Dell Inspiron 15R Notebook
The printing on the right side margins is being cut off. If II print several pages at once the printer runs that pages together.
Make sure the paper size matches the printer setting:
  1. From the software application, click File > Print.
  2. Click Properties, Preferences, Options, or Setup.
  3. Click Paper Setup.
  4. Check the paper size.
Aug 11, 2011 | Lexmark X5470 All-In-One InkJet Printer
Please describe your how can i use in legal page setting in printer sharp ar5516 problem
go to start -> devices and printer -> select the printer -> right click on it -> select printer properties
-> choose page set up -> if you see "page set up option on it" click on it and choose the paper size
legal or anything that you want
and if you dont see page setup option where I have shown, do search for such option in
printer properties
another option is that....
when you give print from word,excel anythig you get windows to select printer, choose the printer
go to properties and all those same steps,
or
in word,excel or other application there is page setup option in file menu (in office 2007 and 10)
if is on "page layout" option.
Mar 14, 2011 | Office Equipment & Supplies
How to print and staple landscape using Canon 3220
HI
You go to you printer properties(you will find it if you right click on the printer driver under printers and faxes in the controll panel),select printing prefrences,page setup,there is a option for landscape printing.Next to page setup is the finnisher settings,select the stapler option.
Nov 11, 2008 | Canon imageRUNNER C3220 Color Copier
Epson r285
open your document and click print, then click on the properties button.Then click on the page layout tab and uncheck the collate button.
This wil print each page on a new piece of paper, the collate option is to print on both sides of the paper.
Aug 08, 2008 | Office Equipment & Supplies
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
