Question about HP Officejet 4215 All-in-One Color Photo Ink Jet Printer
4215xi printer just replaced color cartridge with new one and all the colors aren't printing so tried another new cartridge and the same results are the jets clogged or possibly there's a simple solution.
  • feedman Dec 16, 2007
    We have the same problem. I've tried the third cartridge, and all i get in color is yellow.
    Habit-Forming:
  • 59 Answers
Please check :-
Protective tape on a new ink cartridge has been removed. Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
Then try and do a head clean and printer head alignment.
Posted on Jan 26, 2008
Why is black printing dull/light?
Probably using COLOR to print Black images. Check your printer settings Set to BLACK only.
Also could be from generic copy paper.
Feb 23, 2016 | HP Color Laserjet Cp3505n Color Laser...
In my pixma ip2772,when I print photo then black colors are printing properly but when I print any types of documents then my black color is not working.It's not showing dark.What can I do?
This printer has a separate cartridge for black and colour. When you print pictures, the printer uses all three colours mixed together to make black and does not use the black cartridge. Your black cartridge may be empty or the printhead may just be dried out. Try a head-clean from the maintenance menu and then print a nozzle test. If still no result then try replacing the black cartridge with a new one which has a new printhead as part of the cartridge.
Apr 14, 2015 | Office Equipment & Supplies
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My Officejet R80 prints only in red and black; Any suggestions
Color cartridge dried up..Perform clean cartridges through printer properties.. check,,no result, replace color cartridge..
Sep 01, 2012 | HP OfficeJet r40 InkJet Printer
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
Apr 26, 2012 | Canon Pixma iP3600 InkJet Photo Printer
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
The color red will not print on My Dell A940 printer.
Try find another printer(same model- says printer B)...take printer head from printer B to your printer(says printer A),use your ink cartridge and test your printing....if all color seen on paper, then the problem is your printer head, to make sure is it true or not, use printer head from printer A into printer B.see the result...
May 26, 2009 | Dell A940 All-In-One InkJet Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
