Similiar to earlier posting and my set is almost four years old. These appear prominate on lighter colored back groungs and are masked when there is a dark background.
Here's the scoop about the spots!!! Apparently Panasonic knows about
the problem!! It is a corruption in some eprom. Call Pana or your service center and they will
get someone to come to your home and fix the problem ...no charge!!! I
had mine just done, it takes about 15 minutes tops!!
I was watching TV and the screen went black. I turned the tv off and on and its still black. I also...
(More)
I was watching TV and the screen went black. I turned the tv off and on and its still black. I also heard a low buzzing sound from the back, has the bulb burned out?
TV turns off after 5-10 min. Replaced the bulb about 2 months ago. Couldnt reset the timer because I...
(More)
TV turns off after 5-10 min. Replaced the bulb about 2 months ago. Couldnt reset the timer because I don't have the original remote. Lamp Light has stayed on and message comes on when turning on TV. Now the tv stays on 5-10 minutes and then powers down like sonmeone shut it off. You can turn it back on again without unplugging but same thing happens. Does this have something to do with not resetting the timer or is the bulb going bad or is it something worse?
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light...
(More)
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light comes on and flashes. TV makes a faint rapid clicking noise that might repeat a few times.
pink dot in the middle of the screen about the size of a softball on shows up with light colors on...
(More)
pink dot in the middle of the screen about the size of a softball on shows up with light colors on the screen
