Now...keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15252 / 15254 /
My dishwasher is flashing a green blinking "washing" light when I hit the...
(More)
My dishwasher is flashing a green blinking "washing" light when I hit the "start" button but not coming on. It is just over a year old but of course out of warranty. Any way to reset the unit?
I have a Kenmore 16022 dishwasher that doesn't get through the washing cycle. After pressing start...
(More)
I have a Kenmore 16022 dishwasher that doesn't get through the washing cycle. After pressing start it fills with water and the washing sensing lights come on but it doesn't go further. thanks
