Question about Black & Decker TRO651 Toast-R-Oven Toaster Oven with Convection Cooking
White toaster oven
How do lyou clean the yellow stains off the toaster oven
    Problem Solver:
  • 14 Answers
Posted on Dec 05, 2007
Fan motor
maybe you have stain in motor shaft! you can clean the motor by spraying of WD40. or maybe you have defective fuse thats connected to motor to source! or try to clean the rotary switch!
Oct 14, 2007 | Maximatic RO-1010X 1500 Watts Toaster Oven...
How can I clean my toaster oven?
Cleaning a toaster oven is a simple task; however I will post a great video tutorial that should be helpful.
Jul 17, 2012 | Oster Toaster 4 Slice 7 Settings Food...
My TRO651 Toaster-R-Oven does not work on any function and the blue light does not come on. I removed the right side cover and checked all the connections, then I cleaned the two sets of contacts with fine...
May not be too hard to fix. On the thermostat, you will see 5 wires coming from it. black and white on top (leave those alone), and on the bottom of the switch, there are red white and blue wires.
The white wire with the burnt connector(from use) is the problem. I had that switch apart, seen how it works. The 3 wires at the bottom (red, white, blue) is like a spst center off switch with white being the common center wire. Red is for oven, and blue is for toaster. After I rebuilt the switch the first time, and it happened again, I just bypassed switch by connecting that burnt bottom white connector, to the red timer wire connector. Oven will work, toaster will not. The oven turns off when timer runs out. Can also unplug or turn down thermostat all the way so it does not use much power when done using till timer runs out. If you have a spst(center off) switch, you can mount that too to the side panel if you find one rated for it. Just make sure the bottom white wire is used as the common center wire.
B&D will not sell that switch that is broken. I tried that before I took that switch apart. Glad I did take it apart as I am sure their new switch would have failed quickly as well.
Aug 02, 2011 | Black & Decker TRO651 Toast-R-Oven Toaster...
Have a toaster oven broiler. Had it for years and cannot clean the glass. It looks dirty and terrible all the time. Helene
Hi Helene, Welcome to FixYa. I am Kelly
There are 3 ways we as service techs use on a stubborn glass that is badly stained to get them clean.
1. On a warm not HOT oven. Spray it with "easy off" oven cleaner on the glass only and leat it soak for about an hour. I use thick stacks of newspaper for maksing off the metal while applying the cleaner so as not to get the easy off oven cleaner on the metal. I lift away the newpaper after the application. Then at the end of 1 hour wipe it off. Do a second treatment if necessary.
2. If after the Easy Off cleaning periods you still have the stained glass make a trip to any auto parts store and buy some engine degreaser. (Aerosol) Do the same thick newsprint masking routine as above and lift it off after application. Let it sit for an hour and wipe off with paper towels.
Do a 2nd treatment if necessary.
3. Next to last cleaning use Mr. Muscle Kitchen Cleaner on everrything in the broiler. No masking required. Spray it on... let it sit at least 15 minutes and wipe clean.
Final cleaning use a mild dishwashing soap and water. Then do a fresh water wipe off. Make sure to remove everything you applied as it WILL make your broiler smell bad if you don't get it all off.
Thanks for choosing FixYa,
If you would please.... do post any feedback good or bad after you clean the glass and broiler oven.
Oct 06, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Main problem, bottom two elements have conked out. Where do I get new ones? Next, how clean glass door when it won't come out of slots? Next, what do I use to clean shploops patina off crumb tray?
you can get the new elements from the online sites mentioned below also from and for cleaning follow this instructions
  1. 1)take out a bowl and in that bowl make a paste using the baking soda and vinegar
    2)After making a paste open the oven door with the oven off. Take the sponge dipping it into the paste of vinegar and baking soda.
  2. 3) After dipping it into the paste. Smear it on your oven door. Leave on for about 10-15 minutes longer for more stubborn stains. Now the time is up! take that sponge rinsing it in water and wipe down. Little or no elbow grease is required. Now you have a beautiful oven door.
    This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Mar 04, 2010 | Bella Cucina 13049 1500 Watts Toaster Oven...
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
Toaster oven door
Try They do thousands of parts for white goods.
Dec 03, 2008 | Black & Decker CTO9000 Dining-In Toaster...
Oven is not a month old yet
We have the same problem. We have tried everything to remove the stain. Nothing works. This along with one of the knobs breaking off. Not as quality of a product as we had thought.
Nov 28, 2007 | Rival TO600 1500 Watts Toaster Oven with...
Black & Decker TRO651 Toast-R-Oven Toaster Oven with Convection Cooking Logo
203 people viewed this question
Top Black & Decker Toaster Ovens Experts
Shehu Pro
Shehu Pro
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
