Question about Boss C150 Car Audio Amplifier
Boss chaos 150 200 watt that shows light but doesn't produce sound
I have a boss 150 dual channel 200 watt amp in bridged mode that will come on and display the green light but will not produce sound. its hooked up to two 300 watt pioneer 6*9s if that makes a difference. help me please
  • 1drunkhippie
    1drunkhippie Dec 15, 2007
    dude thanks it works great now
  • 631 Answers
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
300W Pyramid PA305 protection light
What is the speaker load in Ohms that you are running? Or what exactly is hooked up to it? are you bridging it? The protection light will come on if the load is too much for the amp to handel. If the load (in Ohms) is less than the rated load that it can run, it will stop the output to keep the amp from self destructing. The amp will sense that the demand for power will be too high for the amps circuitry which will either make the amp get so hot that it will burn up the copper on the board or more likely burn up the power mosfetts that power the speakers. If the Ohms are within range then it will allow power to flow through the circuit until the rails that the mosfetts are bound to until they get so hot that it will go into thermal protection. So if your amp has both thermal and overload protection lights and the overload is light then the load is probably too much for the amp. if it's bridged in mono the you can only have 1 speaker setup hooked up it if it's a 2 channel amp. a 4 channel amp bridged in mono for both front and rear channels will be able to have 2 speakers rated a 4 ohms each hooked up to the amp 1 set per bridged output or channel.
Try it running in stereo with only 1 speaker per channel and see if it will produce sound. If not then you have an amp that has internal problems and will need to be serviced. Check your warranty to see if you are covered.
Apr 02, 2013 | Pyramid PA305 150 Watt PA Amplifier Car...
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
How do I fix the problem so they work again.?
Jun 08, 2009 | Car Audio & Video
May 27, 2009 | Boss C150 Car Audio Amplifier
How do i bridge 3 subs to a 4 channel amp
My information shows the XM-1652Z as being a 2-channel amp. It will not be stable below 4-ohms in bridged mode. For best power, your subs will need to be 2-ohms with all 3 wired in series. This will present a 6-ohm load to the amp. After wiring the subs in series, connect the positive speaker wire to one channel (+) and the negative speaker wire to the other channel (-). For the 1652Z no other wiring is necessary. For subs you will also want to set the LPF (80Hz) switch to the "ON" position (to the right).
Keep in mind that the rated output is only 400 watts RMS at 4-ohms in bridged mode. That's kinda wimpy for 3 subs. You would probably obtain better results from two 2-ohm subs, each connected to a separate channel. That way each sub would be getting 200 watts RMS, still low but there's lots of good subs that will sound pretty loud with 150-200 watts
Mar 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Low amp output
Make sure the BOSS isn't in "Protected" mode (Red led lit) and connect the speakers properly (check the connections if they are in "bridged" mode).
Also, make sure you set the cross-over, bass boost setting, bass volume control and the bridge mode according to the speakers you are connecting. Check the input level too.
The BOSS amplifiers are of very poor quality and it can be easily broken. Maybe yours is broken.
Feb 15, 2008 | Jl Audio E2150 Car Audio Amplifier
Not producing sound
It sounds like the power supply may have failed. I'm not familiar with that particular Boss amp but many amplifiers will light the power indicator even though the amp isn't operating.
Have you checked your speakers to see if they're blown?
Have you checked the wiring to make sure the speakers are still connected to the amp?
Dec 19, 2007 | Car Audio & Video
Boss C150 Car Audio Amplifier Logo
384 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
