Question about Panasonic NV-GS30 Mini DV Digital Camcorder
Panasonic NV-GS30 firewire connection
I am unable to get my camcorder to connect to PC via newly installed Firewire connector. Tried Camcorder on friends PC same result. Is there any other configuration I have to do to the camcorder to get it to work. I have it powered on and set to VCR. I thought that the PC (using XP and Movie Maker) should detect the camcorder and instruct me to start. Any ideas. Or is just that the DV out of the camcorder broke.
  • 95 Answers
You must a software that will make easy for you to capture like Adobe Premier or some other application that is applicable for firewire or IEE1394.
Posted on Aug 13, 2008
Panasonic nv gs30 can support mac
Connect the camera to a Mac and open iMovie then capture.
You will need a 4 to 6 pin firewire cable.
Note: Some Macs have a nine pin socket and some base models have NO firewire socket.
Mar 06, 2011 | Panasonic NV-GS30 Mini DV Digital...
What leads do I need to connect my Panasonic NV-GS30
There is an optional cable available for your camera called the VW-CD1E that will make use of the firewire (DV) port on your camera. You will also need to have some sort of a video capture program like Adobe Premiere so that you can download the video from your camera and then edit or display it. You should be able to order the cable from any Panasonic retailer. The better electronic / video stores will probably have it in stock.
Apr 18, 2010 | Panasonic NV-GS30 Mini DV Digital...
Where is firewire slot on panasonic mini dv nv-gs30
Usually it's inside the access door on the side. It looks kind of like a usb cable connection.
Jill
Nov 30, 2008 | Panasonic NV-GS30 Mini DV Digital...
Panasonic NV gs 27 Vista Support
Vista is notorious for not recognizing firewire unfortunately. Here is a link to a Microsoft Knowledge Base article that should help your situation. Hope this helps. Good luck.
Microsoft's firewire solution
Oct 18, 2008 | Panasonic NV-GS27 Mini DV Digital...
Connect to laptop using vista ultimate and firewire
I checked on Panasonics USA support website and neither of these two model numbers appear.
Here is the link to the support page:
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-Digital+Camcorders
There is a phone number to Panasonic support on this page as well as the international link if they were purchased outside the US.
Jul 06, 2008 | Panasonic NV-GS50 Mini DV Digital...
Connect to PC
firewire cable-win 4 pin to 4 pin- mac or desktop 4 to 6 pin
May 26, 2008 | Panasonic NV-GS30 Mini DV Digital...
Connect to Pc
You will need a firewire cable.
It has 2 different connectors on it. On small 6 pin plug for the camera end, and a larger (almost like a USB but with tapers at one end and slightly thicker) plug at the other.
Your computer will also need to have firewire either built onboard, or via an addin card that you can purchase at any PC shop.
The connector for the camera side plugs into the side of the camera near the battery.
Hope that helps =)
Apr 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
I seem unable to connect my Panasonic NV GS30 via firewire tried 2 cables and 2 computers windows does not see camera like it used to. Only other fault that has appeared is jitter on viewfinder display.
Hello, and maybe this can help! Sense your viewfinder has jittered, your computer has reconized it. However, your software that you are using on the computer may be corrupt. i suggest that you insert the cd and instead of removing it, click repair. If this does not work, try checking the cable and make sure that it has a tight connection. One question. Did you pc make the standard beep noise when you plugged it in??? if not, then it is your computers. most likely, it is your camera or your software.
Feb 27, 2008 | Panasonic NV-GS30 Mini DV Digital...
Panasonic NV-GS30 Mini DV Digital Camcorder Logo
241 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
