Question about Samsung Digimax S730 Digital Camera
Flash I know when taking a pic, according to the lighting the flash is automatic; however, it never turns on. Maybe I can do it manually, but not sure how.
    Problem Solver:
  • 5 Answers
When in the auto setting, press left (I think - if not try up, down or right) on the circular button... this well amend the logo on the left hand side of the screen, One is like a bolt of lightning with 'a' for automatic, crossed out for not at all, and the sole bolt of lightning is premantly on. Using the up button on the circular button (or alternative) will amend the red eye light on or off. Turning this off will enable to take photo's quicker
Posted on Dec 19, 2007
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
Is there a way to turn off the flash?
The flash is automatic, you cannot control the flash. But you can put some black tape over the flash if you really don't want flash. Remember though, if the camera meter decides flash is needed, then your pictures could turn out dark/underexposed by covering the flash.
The manual can be found here: http://www.olympus-europa.com/consumer/208_manuals.cfm?prodID=P_N1246352
The manual says use 100, 200 or 400 iso films.
Maybe try high iso film like 800 iso or 1600 iso, best to try this out ahead of time to make sure you are satisfied with the results. The high iso films need less light so should perform better without flash, but the camera may not be able to rate these films correctly, trial and error is definitely required.
Oct 22, 2010 | Olympus TRIP AF 60 35mm Film Camera
My camera doesnt take pics @ night Maybe flash
First make sure that the camera has fresh batteries. Then see that the flash setting is either 'on' or 'auto' or any graphic mode like a lightning bolt.
If this doesn't help, the flash might be damaged. Any camera shop can check this quickly.
Nov 26, 2009 | Moultrie Cameras
My pics come out half black when I use the X-370 flash
motley45
this happens when the shutter speed is not correct. set the speed to 1/60 sec.
if the X-370 flash is new it may not be compatible with your camera. with the flash turned on it should set the shutter speed automatically to either 1/60sec or 1/125sec. looking in the finder the shutter speed should not change to various amounts of light. if the shutter speed changes with the flash turned on it is not dedicated to your camera.
May 03, 2009 | Minolta X-370S 35mm SLR Camera
My flash is not working
Change your batteries, the light should not be orange, but a brighter shade of red, or maybe GREEN.
Apr 07, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I need the manual or instructions to my camera.
i dont know how to turn on the light/flash of my digital camera,even i put in the flash mode it doesnt work.it is a primier digital camera.
Jan 13, 2009 | Cameras
Nikon Coolpix digital camera L18
The red light is probably the focusing beam. I'd guess that your flash is turned off somewhere in your settings. Go through the menu and if you find that it is not turned on there might be a hardware problem. Also, if the flash is set to automatic, it will not work when it thinks there is enough light to take a good pic.
Nov 07, 2008 | Nikon Cameras
Built-In Flash
whether of not your camera has different flash settings really depends on the camera. the best solution is to carefully read the manual that came with the camera...
Jun 28, 2008 | Cameras
Need help w/ night pics at softball games
On camera flash will not help in out door sports facilities. If you have maxed the ISO and set it to Aperture priority -which will slow the shutter down and give you camera shake and blurred images as the players dart about- Ho Hum you ain't going to win this one. Buying a bolt on flash I doubt will be powerful enough either, take what you can and get to grips with a good image editor- Though I guess the results will still be 'noisy'
Mar 09, 2007 | Olympus EVOLT E-500 Digital Camera
Flash detail
Use the right arrow button on the arrow pad. There is a little pic of a lighting bold beside a pic of a camera on the top left hand corner. Push the right arrow button and look at that lightning bolt you will see it changing. There are three different ones. One has a ling through it and that means no flash on had an "A" on it that stands for automatic and then you will see just a pic of the bolt without anything. Not to sure what means either. Hope this helps.
Dec 30, 2006 | Polaroid izone 550W Digital Camera
Samsung Digimax S730 Digital Camera Logo
90 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
