Question about Apple Bundle Mac mini 1.66Ghz Intel Core Duo with 1GB RAM Installed (Z0D1) PC Desktop
Installing ram upgrade
How to install new ram on Toshiba Satellite L35 series
I have the 2 new modules (each 1 gig)
I have opened the case
The lower socket is occupied with the original 500mb module
The upper one is supposed to hing upward, but seems reluctant to move. How do I make it hinge upward so I can then hinge upward the lower one too, and remove the old module and install the two new ones?
Don't want to break anything
Jeff
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Pharlap33
YOu have to carefully, separate the 2 little brackets and place the new ram into it. it should work if you do carefully of course.
the idea is put it in the slot carefully.
Posted on Dec 06, 2007
Add ram Satellite u845
Power down your Toshiba Satellite.
Unplug it from the wall.
Turn the machine over and remove the battery.
Locate the RAM compartment cover, which is usually located somewhere in the middle of the underside, and is about 4-by-4 inches.
Unscrew the RAM cover screw with a Phillips screwdriver and set aside.
Ground yourself by touching a metal object.
This will release any static electricity built up in your body, which can harm computer chips and components.
You can also use an anti-static wristband while you are working.
Remove RAM modules if needed.
This is most likely if you are upgrading the present RAM capacity with a larger RAM chip.
Press your fingers on the clips on either side of the chip to pop it out of the socket.
Pull the chip out of the RAM compartment, holding it by the sides of the circuit board rather than on the chip.
Insert the new RAM module into the socket. Align the RAM module so that the notch lines up with the tab on the side of the socket.
Gently lower the module into the socket. Press into place with your fingers.
Replace the RAM compartment cover. Insert the screw and tighten.
Replace the battery and secure with the lock.
Plug the Toshiba Satellite laptop back in and power up the system.
The upgraded RAM should be automatically recognized.
hope this helps
HOW TO INSTALL MEMORY UPGRADE TOSHIBA SATELLITE LAPTOP
not sure if this is the right laptop
http://www.youtube.com/watch?v=RdCzsjDp_lc
Oct 12, 2012 | Toshiba Satellite U845-S402 14" Notebook...
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
I need a guide in order to upgrade the memory of my Toshiba Satellite P205D-S7438. I'm not an expert at all but I already did so on another laptop (another brand too) and I know it is possible for me as...
This is real easy underneath you will see a large flap undo the screws hold it, and remove, you will see the RAM slotted into the socket,simply obtain the correct RAM for your laptop, and slot it in besides, or instead of, replace cover, and reboot, it will automatically be detected and used. If you have done it before then you are on your way to being an expert.. Oh we always say and "X" is an unknown quantity, and a "Spurt" is "Drip" under pressure...Xpert... < Joke.
Mar 08, 2010 | Toshiba Satellite P205D-S7438 Notebook
I tried to install 1gig of ram into my toshiba and it won't start
reinstall memory (check specs if they exactly the same as old one before reinstalling) if wont work install old memory , if works you may have a bad 1 gig stick
Dec 29, 2009 | Toshiba Satellite M35X-S114 Notebook
My computer freezes when I add ram to the second memory slot. I have tested three different ram components 512MB and 256MB and none of them work. Is there a way to fix or replace the so that I can use both...
Have you tried reversing the two ram modules? Or better than that, install two new 1GB modules. And if you do not want to do that make sure the Slot 1 has the larger of the modules. Do you know that the memory modules both work?
Sep 25, 2009 | Toshiba Satellite Pro M15-S405 Notebook
What is required to upgrade my Toshiba A20, to a new faster machine, without spending big $$. Or upgrading to a new machine. I have already upgraded the ram, to its max..!
upgrading your PC or laptop means updating every software installed in your PC or laptop except those installed by you...
please vote for me...im sure this will solve your problem...
Jul 01, 2009 | Toshiba Satellite A20 Satellite A25 Series...
Maximum Ram upgrade?
this is the link
http://www.memorystock.com/memory/ToshibaSatellite2400103.html
In this link u have following details
1)Maximum capacity RAM Information Available
2)Toshiba Laptop Memory Installation Video
3)Laptop Memory SODIMM Installation Guide
If you r Satisfied with information provided from my side please give me good ratings thanks
If u require more information search in google
Aug 09, 2008 | Toshiba Satellite 2400-S251 Notebook
P35-611 Memory upgrade question
hi try going in to your bios at the start when starting your pc up press f2 this should get you in to your main board settings finding the sys on your bios when you go into the bios it should come up with your cpu hard drive and mem installed if you need to reset this to 2 gig if you dont and its reading 2 gig then go to save exet yes to this and reboot your pc this may fix your problem .
this may just be a read problem and it needs to learn that you have a 2 gig mem
if not let me know and we can try another way for you ok
hope this helps ok
all the best
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
