In my hp w1907 icant select a booting device.ihave to install a new os but icant boot from cd rom!!i have tried del button but it doesnot show any option to change the booting device.onstarting my pc it says press esc to select boot device,i have done but cant change!!please help
To open the BIOS Setup screen:
Turn off the computer and wait five seconds.
Turn on the computer.
* When the first screen displays, immediately press the F10 key if your
computer was built in 2006 or later (came with Vista).\
* Press the F1 key if your computer was built before 2006 (XP or earlier).
* Press the key once every second until a BIOS Setup utility screen opens.
NOTE: On some Compaq Presario computers (before 2002), press the F10 key at the logo screen.
Use the keyboard to move through the menus
Hope this helps a bit, don't give up check which procedure applays for your system and be
1. Fast to press at the right moment
2. Just start from the begin again if you missed the moment.
Success with your OS installation!
Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
Hope it helps.
