Fuji FinePix 8.3-Megapixel Digital Camera - A825
Problem for Fuji FinePix 8.3-Megapixel Digital Camera - A825
My finepix A825 has a problem where it seems to
By ppaula40 on Aug 29, 2009
My finepix A825 has a problem where it seems to default to internal memory. After taking 3 or 4 pictures it states the internal memory is full. However, when I insert a memory card the camera doesn't recognize it. I have tried to format the card but still get the same message. I'd be really grateful for any advice. Thanks
Comments:
Aug 30, 2009
- Thanks, I tried what you suggested but it still won't work. I erased the pictures, pressed the reset button and then switched the camera off, removed the batteries and the memory card like you said. I did notice, however, that when I switched the camera back on I got the message "Images saved to Internal Memory" and there is a small camera logo at the bottom of the screen with the "in" inside. I can't figure out any way to change this setting from internal memory to memory card???????
Aug 31, 2009
- Thanks, I tried that but when I select "copy" its says "no card", although the card is in the camera. I tried a different memory card but that does the same.
Sep 01, 2009
- Yes I did format the memory from the camera menu, but still no luck!!
Best Solution
posted on Aug 30, 2009
Very Helpful)
typrice
Rank: Wiz  Fuji Cameras & Camcorders  Expert
Rating: 80%, 1228 votes
Are you trying to format the card in the camera? That's the accepted way. Go into the setup menu and find an entry for "reset"...try that. Try removing the card and battery...press all the buttons...insert the card and then the battery..try it. Remove the card and erase the pictures the camera says are in the internal memory.
Comments:
Aug 30, 2009
- First, let's transfer the internal memory to your card. Insert the card into the camera. In the setup menu, select "copy". Select the setting for transfer of "in" memory to memory card. Press menu/ok to confirm. Next, remove your card. We're going to format the internal memory. In the setup menu, go to "format" and follow the on screen instructions. Finally press menu/ok (takes about 15 seconds). Now, with no card in the camera, the camera icon with the "in" is in the lower corner. When you insert your card, that should disappear. Let me know how it turned out.
Aug 31, 2009
- Did you at least try to format the internal memory?
Sep 01, 2009
- At this point, you should e-mail a tech person from the support section of the Fuji website and explain your problem. They may have a download or a work-around.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for your help, much appreciated. " - ppaula40
Popular Solutions for Fuji FinePix 8.3-Megapixel
Questions and Unsolved Problems for Fuji FinePix 8.3-Megapixel
Do you recommend Fuji FinePix 8.3-Megapixel Digital Camera - A825?
Answer
Answer
The lens will not retract on my Fuji FinePrint A820. It starts to retract, then extends and the... (More)
Answer
I have a similar problem with my camera, Finepix A825, but it's not with regards to the software... (More)
Answer
when i try to take a picture... the screen is white..can,t see what i'm shooting at..and if I take a... (More)
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
