Question about Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
How do turn the temp up on a norlake walkin?
Our norlake walkin is way too cold. It could be a freezer. It is temping about 30 degrees and all the veggies are freezing. can you tell me how to turn the temperature up? I have looked but I can not find the dial inside of the walkin. The serial number is 88401359 and the model and job number is klc66 cr 26 and 11458 2ka. Thanks
  • 40 Answers
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Posted on Dec 05, 2007
Need lowest actual temps achievable by various upright freezers.
no rule of thumb
maybe if you got a different thermostat that has a lower setting than standard
however as upright freezers are very bad freezers compared to chest type freezers the lowest reading will be around the -35 degrees C
Why very bad -- every time you open the door you dump 20 degrees out onto the floor and the temp difference is more pronounced than opening the lid of a chest unit which keeps all of the cold in the unit
remember the colder the setting the more the compressor is working
Jul 08, 2018 | Freezers
Freezer thermostat was set at 0 degrees unit went down to -30 degrees. I increased temp on thermostat 3 degrees 3 times each over a 3 day period. The thermostat is not responding. I have the thermostat set...
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Aug 02, 2010 | Nor-Lake KLF7766C Commercial Freezer
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
We have norlake walk in freezer and the problem is buildup ice and the temp is 35degree right now how to bring the temperature back to zero degree
You have to defrost the coil by turnning of the unit and to make it faster leave the inside fan/s running.But if it's building up ice and the fan/s inside works ,is most probably that the unit is low in refrigerant(freon) , or the defrost system is not working.
Sep 25, 2009 | Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Temp -35 degrees,freezer runs all the time
I assume there is no manual control for setting temp. so the thermal sensor or control circuit has failed and it is just staying at its maximum.  You will probably get more help from the manufacturer but their website is somewhat disjointed; looking for contact info for your product ends at one point and then shifts to their scientific product line.
The only general contact info I found is here:
Nor-Lake
You will in any case need to have the correct model number at hand since the subject line doesn't sound like your freezer.
Apr 02, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer tempature
Depends on the product you want to keep in the freezer. Usually you want to try and stay between 0 and +10 degrees for most items. Ice Cream must be -10 degrees minimum. Any warmer and it won't keep. Hope this helps.
Good Luck
Dec 24, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
406 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
