Question about Ricoh Aficio AP3800C Laser Printer
Printing fuzzy / bleed text with fuser saying needs changing soon!
Hello prints are coming out with the text (black) fuzzy / bleed/ like a spider has crawled throught them. Trouble is it is only some of the pages in a 28 page report (duplex).
Any ideas?
Oh yes the printer is saying fuser needs changing soon. What goes worong in fuse is there any thing i can do to keep it going?
  • SIEW Dec 14, 2007
    COLOUR SHIFT ON THE ENTIRE IMAGE, AND THE AMOUNT OF SHIFT DIFFERS AT FRONT, CENTRE AND REAR OF THE COLOUR COPIER MACHINE MODEL RICOH AFICIO AP3800C
  • 417 Answers
Hi the blurring maybe down to the machine needing a color registration. Press the menu button then press either the up or down arrow to Maintenance press enter or # the using the up down keys again select color registration enter or # then print registration sheet once printed select M Y C or B and input the number that is on the printed sheet that corresponds to the straightest line. Once you have done this exit and try printing.
If that doesn't work then within the driver on the computer under printers and faxes right hand click on the printer select properties. Within properties you will be able to change the graphic mode please try this.
The fuser unit will need changing as they only have a life span there are no benefits to resetting as you will need to change it anyway. If you do not change the fuser then it will break leaving you with a bigger problem.
I do hope the above works for you.
Thanks J
Posted on Jan 02, 2008
Fix heater
The printed matter is erasing because of faulty "Fuser Assembly".Fuser heater is not producing the specified temperature to fixup the image on the media. Replace it..
Oct 16, 2013 | HP Office Equipment & Supplies
Fuzzy printing
Try a reset to factory defaults. Or a hard reset. Or driver reinstall. If nothing works then you have a physical issue with unit.
Sep 06, 2017 | Konica Minolta bizhub C250 All-In-One...
Printing dirty
This is caused by one of 2 things. It is either the toner cartridge or the fuser film is going bad. Your printer may be printing fuzzy, blurry, or other faint text because of dirty print heads, so try to clean them, including roller.
Apr 27, 2011 | HP LaserJet 2420 Printer
We have a HP Color Laserjet 3600 printer. Printing a text, the right side is very pale. Printing pictures, they turn out unclear with strange colors. We have new cartridge
The laser unit on your machine may be dirty,
The first colour that normaly goes fuzzy is the red.
The problem may also be on your fuser unit,
Rub your finger over the printed area, and if the image gets smudged the fuser unit isnt fusing the toner proprly
Feb 10, 2011 | Office Equipment & Supplies
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing text with no margins
You need to make sure that your printer is capable of doing this. Most of them are not. If your printer is definitely capable of printing "full bleed", then there should be an option in the print dialog box that allows you to specify printing to the edges.
Mar 11, 2009 | Broderbund PrintMaster Platinum Version 18
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Ricoh Aficio AP3800C Laser Printer Logo
196 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
