Question about Dacor DMT2420 1200 Watts Microwave Oven
Hole in the microwave
Hello how are you. the other night i was poping popcorn and my microwave starting smoking. it burnt the popcorn i cleaned it out and took all the kernals out i turned it back on it it starting burning again. i decided not to use it a gain i would waite till the morning .so i did and the next thing you know the microwave sparked and the dish that i had melted itook it out and there was a metal piece attached to it know ther is a whole in the microwave i can see into it should i through it out or is ther a way to fix it
  • Dacor Master
  • 9,098 Answers
Where exactly is the hole in the microwave?
If it's a hole in the actual metal chassis of the oven, it should not be used and you should contact Dacor customer service:
http://ww2.dacor.com/services/index.asp
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced. Dacor can help you find one.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 06, 2007
My Daewoo Micro Wave Was Spitting Flames Last Night Due To A Hole In The Wave Plate
Hello Stephanie.
Get a new filter and try again.
Otherwise scrap the micro.
It the filter plate rusted through, or is it burnt?
The microwave's Magnetron-wave-guide is just behind this filter plate.
Looks like a small tube with a silvery cap with hole in center.
Very hazardous condition here.
The high energy from it is damped by the filter.
Is there food in the micro when arcing happens?
An empty micro will arc.
Sep 23, 2017 | Daewoo Microwave Ovens
Frigidaire microwave won't start when door is closed. It looks like the door does not latch properly. It worked 20 minutes ago and last night. How do you troubleshoot and/or fix the switches.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Feb 23, 2013 | Frigidaire FMV157GM Microwave Oven
Light inside the microwave is out.
Hello, This is a repeat of a previous post I made some time ago. It is for your make/model, if it is built in.... Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine! If, however, yours is an over the stove type, it may be possible to remove the front grille and replace the lamp.
Regards! --W/D-- feel free to rate this solution! Thanks!
Jul 31, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker Model No. JVM1650AB 003
Hello Diana,
Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
Good Luck !
Sep 14, 2008 | Microwave Ovens
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-402JKF microwave
It sounds like your electronic board has malfunctioned. It may have to be replaced, sometime it is cheaper to buy a new oven. Technician's fees and parts may be more than it it worth.
Dec 25, 2007 | Sharp R-402J Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
184 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
