Question about Vizio P2 42 in. HD-Ready Plasma Television
Yellow screen on tv
I have a bush tv and on and off for a while the screen goes yellow and the picture is a bit blurred,it usually rights itself if you turn off the tv and wait a while.now this does not seem to work,sound is fine but everything is yellow.you can make out what is happening but its not clear
  • Anonymous Dec 06, 2007
    yeah... im trying to hook up my xbox 360 to it in 1080i but its yellowish in color....
  • hossamk Dec 18, 2007
    hi everyone i have the exact same problem with my xbox360 on the plasma it turns yellow does any one know if this is from the xbox360 or the plasma? and any one have a solution?
Full yellow screen on one channel on plasma tv, no other channels does this occur
Posted on Sep 26, 2008
Lots of times when you go and buy your tv's for example like big screen... usually it will tell you that you shouldn't play like play station and things like that on them and i don't know why...
Posted on Feb 14, 2008
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Sony TV LCD screen blurred down one side when switched on and then after warm up appears to fix itself.
My KDL-52W4100 just started doing the same thing. It blurs down the right side of the screen, then goes back to normal after it warms up. Does anyone know whats up with this?
Mar 24, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Blurred appearance when turning on
There are few dried capacitors at the power board. They need to be replaced.
Feb 24, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
Red band on flesh tones (50V500)
This is the first sign of a failing Red Picture Tube. Tubes will blur to the right when they get older. You can try to turn the screen control for the red gun down so the blur goes away. But eventually it will get worse.
Dec 17, 2008 | Hitachi 60V500 60" Rear Projection...
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
BUSH LCD 17TV004 picture goes off!!!
if yo know how to solder , re solder your tv, second adjust the IF transformer by using the plastic or wood stick. IF transformer is looks like a cube made of metal with an adjustment screw at the top. try to adjust it and observe what happen.
Oct 16, 2008 | Bush 5693D 24" TV
WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Aug 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Bush DVD2038
here is the link to the bush support site; http://www.albaplc.com/html/Support.htm# Although they have no instructions online they claim they will be available soon. If you can't wait, Check this thread; http://www.fixya.com/support/t147105-bush_digital_set_top_box_came_no the cables described are a standard cable available in any store, usually described as a "Triple RCA Stereo/Video cable" or something similar - check the picture. If you want a few more detailed pictures go to this link, there are many; http://images.google.com/images?hl=en&q=triple+RCA+cable&gbv=2 The yellow is for video, red and white are for left and right audio channels. You probably have the same colour connectors on your tv, in which case just plug yellow-yellow etc. If not, then please post back the make and model of your TV, or a photo of the connection options you do have, and we can talk you through it, there are many different adaptors available for practically any configuration. To get the TV to diplay the DVD channel is a different procedure for most TVs, so please give details and we can help get you watching. Hope this helps :)
Jul 04, 2007 | Bush DVD2038 DVD Player
Vizio P2 42 in. HD-Ready Plasma Television Logo
660 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
