Question about eVision EC720E 20 in. TV/VCR/DVD Combo
Tv turns off by itself in 3 seconds and vcr makes noise
My TV turns of in 3 seconds and will not stay on with remote or without please help love my TV.
  • 3 Answers
Take out the jammed VCR tape in it. Worked for me.
Posted on Apr 30, 2008
Jumbo Control Code
The codes for this remote are different depending on whether you are trying to control a Sony TV or a Sony DVD player. Please post again with more information, or use the auto-search function of this remote.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 18, 2009 | Innovage Jumbo Remote Control
What do I do when my Emerson TV keeps turning off by itself?
This is probably due to dry solders in the power supply area of the tv... next time when it powers off give it a whack on the side and see if will just light up for a moment.. If it doesn't just open the tv and check for dry solders, loose contacts and faulty capacitors.. PS:I would not task some one without experience in electronics to handle this one. This shouldn't cost you much even if you hire a tech anyway..
Feb 29, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Programming the innovage remote
  1. Turn on your TV.
I hope that helps.
Oct 04, 2009 | Innovage Jumbo Remote Control
Cannot get channels with remote stuck on AV2/3/4/5/6
The TV button on the remote is to select TV mode for the controller. STB, VCR & DVD do the same for their respective devices.
The A/V should select the external inputs by itself. If not try each of the Panasonic codes in turn:
0011, 0021, 0027,0029,0039,0072, 0102
Enter the codes as follows:
Press and hold TV for 3 seconds until the TV key flashes and then stays on.
Enter one of the codes (above)
TV key should flash twice. (if not go back to the beginning)
Try pressing the buttons on the controller. If all the functions do not work, try the next code.
Aug 03, 2009 | Rio Go Video DDV9475 Dual Deck VCR
HELP ME TUNE CABLE THRU VCR TO TV...PLEASE
If you can get a picture on your TV when you watch a video tape you are half way there. On the back of the VCR there are two coax connections, you may need a flashlight but one will be labeled IN and the other OUT. The one that is labeled Out will be connected to the TV. The other one (IN) is where the Cable from the wall connects into. After you have the connections made turn your TV to either Channel 3 or 4. You will now use your VCR remote to change channels.
These are the basic instructions without knowing what model VCR you have. If the TV will not stay on channel 3 or 4 then you will either need to get it repaired or get a new TV.
Apr 24, 2009 | Televison & Video
Code remote to tv
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Mar 07, 2009 | Jensen 143307 Remote Control
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Jensen Universal Remote
Sorry the manual was not the correct one for this remote. I thought it would provide simular codes to your product.
JVC DVD 0558, 0623
Regards,
VOTIT
Sep 14, 2008 | Jensen 143307 Remote Control
Allan
JVC DVD 0558, 0623
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 01, 2008 | Jensen 143307 Remote Control
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Oct 28, 2007 | Zenith ZN110 Remote Control
eVision EC720E 20 in. TV/VCR/DVD Combo Logo
230 people viewed this question
Top eVision Televison & Video Experts
Marvin
Marvin
Are you an eVision Televison and Video Expert? Answer questions, earn points and help others
