Question about Keurig Elite B40 Coffee Maker
Descaling Completed the process light is still flashing. How many times should I have to do this?
  • starfleet Dec 09, 2007
    Ours too. It constantly calls for descaling, and is quite eratic with the volume of coffee provided per cup. It has also stopped "whooshing" at the end of the brew cycle as it used to do to clear out the k-cup.
  • Robin Joy Jan 27, 2008
    descale light wont turn off and water comes out slow only half a cup of water
    sound not there at end
Call Keurig They are replacing mine with a new coffee maker
Posted on Feb 02, 2008
Des along light still flashing after des calling process completed can anybody help
if the descale posses interpreted its wont tern off
you have to go to menu and adjust the water hardness then do the descaling in full posses
Apr 14, 2015 | DeLonghi Magnifica ESAM4200S Espresso...
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
How do i get the red light to go off on my coffee maker i already descaled it
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will be empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
The light wiill automatically go off once the descaling program has been fully completed.
Mar 20, 2010 | Braun Tassimo Espresso Machine/Coffee...
After descaling the red light will not go off . I used a full tank of water,and a fresh tank after that.My product said cleaner not descaler - does that make a difference.
Use a citric acid based descaling solution rather than a cleaning based solution.
Feb 04, 2010 | Braun Tassimo Espresso Machine/Coffee...
How do |I get the red light to shut off? I have already descaled etc. Thank you
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
Sep 25, 2009 | Braun Tassimo Coffee Maker
After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Oct 31, 2008 | Coffee Makers & Espresso Machines
Solis Palazzo Espresso Machine
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
May 29, 2007 | Solis Palazzo Espresso Machine
Keurig Elite B40 Coffee Maker Logo
619 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
