Question about Archos 504 500870 Digital Media Player
How do I get my Archos to work ont
I have put the lead in the front of the Tv and plugged the archos in, but I cant get the picture on the tv.
Go to the DISPLAY folder on the Archos player. Scroll to Video Output. Swiitch Internal LCD to External and then switch video input on your TV.(Video 1,Video 2 CH 3 etc..) You may have to try various settings. Also, in the DISPLAY folder,scroll to External Display and set to Composite(red/white/yellow) or Component or SVideo depending on which connection you use.
Posted on Feb 05, 2008
  • 3 Answers
If you are using an Archos cable, when you plug in to the tv, you should switch to the video 1 or line in source, probably using your tv remote labeled "input"
Posted on Dec 28, 2007
I CAN RECORD FROM MY TV BUT I CANT GET MY ARCHOS 5 TO SHOW ON THE TV ,WHEN I PLUG MY ARCHOS INTO THE DVR STATION THE OPTION TO SET IT UP FOR TV DOES NOT COME UP . I WOULD BE VERY GREAT FULL FOR ANY HELP,...
You should swtch your TV to the video mode on to the video output chosen for the device. Check the video connecion type by following the output cables from the DVR station or charging dock to to TV. it could be video 1, 2, 3 HDMI, Color stream HD1 , Color stream HD 2, by scrolling down on the video mode list you should get the picture on on of them with correct video mode. or like i was saying follow the output cable from dvr station to Tv to see which video mode it was connected.
Jul 30, 2009 | Archos 5 MP3 Player
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
My archos 604 won't play on my television.
Hi,when you connect it to TV,I believe you switch to AV mode on TV to allow signal to be shown on TV,do you ??.
If you did it but no video ,than make sure your AV cable should go all the way down on the plug on Archos.it is a fancy plug sometimes stays out half way
kazim
Jul 15, 2009 | Archos 604 WiFi Digital Media Player
MININ DV TO ARCHOS
Initially, it would work better if you can provide the specific model numbers of the Sony Mini DV Cam and the Archos. Assuming all things even, most DV cameras have an analog A/V video OUT, in turn some Archos with recording capability have an analog A/V video IN. If this were the case, then it would be a matter of getting the right connectors/plugs + cable and/or adapter/interface.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Archos AV700 Digital Media Player
hi i found my own soulution for recording i will tell you an easy way fist of all you need another freeview box only connect this to your archos and have the other box connected like normal to your tv and place your archos and other box near your tv buy a 2 way splitter from wilkinsons and connect this where your ariel box is probably near the window and get another tv lead to reach your freeview box for the archos this means you have a connection running from the tv box for your normal tv and f box and another for the archos and f box cos of the 2 way splitter you can then record on the archos from the f box and watch another channel on your tv then playback later what you recorded of your archos on your big tv please let me know if you sort this and let me no if you get stuck its great when you get it all set up and it works thanks.
Nov 09, 2008 | Archos 405 Digital Media Player
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370172642094
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
How to record from DVR station
hi there, it should be easy, if your wanting to record off the tv/dvd or video you need to plug (lets say your using phono leads,the ends with red,white,yellow on them) into the output on the video (or what ever the device) the on the docking station plug them into input. then on the archos go to the videocorder n away you go. hope this has help`d
Feb 23, 2008 | Archos 604 Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Connect My Archos to my TV
Archos has a site with a video demo on how to connect all leads
Mar 21, 2007 | Archos AV 500 400-Hours Video Recorder
Archos 504 500870 Digital Media Player Logo
113 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
