Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn air oven won't turn off
Blew a fuse for some reason .After looking in the back it looked like the element connection had touched the side and arc- ed .Put a new connector on and turned the breaker on and now the element stays on even with the oven off. Thermostat????
  • tspinc Dec 10, 2007
    Thanks for thr help you were right on .It was the digital thermostat / sensor .Took the boards off and tested to find one relay stuck or weleded shut from the blown fuse i guess. Took it off sanded down and seems to be working fine so far .I had priced the thermostat at 155.00 so it looks like i can buy someone a nice christmas present . Thanks again
  • kolburn May 07, 2009
    Just installed a used Jenn Air WW27430 - when I tested the unit it seemed ok except for a quick flash/bang about 30 seconds after connection. However, now the lower oven element stays on regardless of oven setting. Sounds like I have the same problem as in this post - any further details on what I should be looking to fix/replace/repair?
  • 833 Answers
Maybe, if you have a mechanical type of thermostat. Could also be the circuit board. Wonder why you blew the breaker in the first place. If the unit is digital, the thermostat is really a sensor, a relay and assorted electronics. The relay and electronics are on a circuit board. That's what you're going to be buying.
Posted on Dec 07, 2007
Ad're welcome. Bear in mind that those contacts will corrode. Your last step is to close them over some typing paper and pull the paper through the contact. It will clean it a bit better than just sanding. You may still need a new relay. Here's a trick: if the relay coil voltage is 12 VDC (many are) you can get an automotive relay and adapt it. I got 3 years out of one on a microwave until something else finally went on the board.
Posted on Dec 10, 2007
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
Should the heating element on my oven be entirely red ? 80 % turns red right now.
it sounds like the heating element you bought is damaged or burnt out.
return it for an exchange
May 03, 2012 | Jenn-Air Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
I have a Jenn Air W131 model wall oven and I believe the lower heating element needs to be replaced. I will set the temp at 350 and it doesn't heat up at all. Is my assumption right that that is what...
If this is the problem no it isn't hard at all. Should be able to change right thru the oven without pulling out of wall. Make sure power off while doing this tho. But ist make sure broil does work.
Feb 01, 2010 | Jenn-Air JJW8330D Electric Single Oven
Jenn-air ww30430w dual oven, lower oven, lower element not heating, upper broil element working fine
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Jan 03, 2010 | Ovens
Replacing heat elements in oven
To replace oven heat element follow the steps below carefully
Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    Jenn-air stove Model SCE30600B. Won't heat
    check all the wiring at the main bus, and at the board connections could be a bad board
    Oct 08, 2009 | Jenn-Air Ovens
    Oven control panel or display window does not light up anymore. Can't see what temperature oven is at or the time or anything else for that matter.
    Could be a fuse or a bad control panel. Unplug the oven, take the panel off of the back and look for fuses. If none, call Maytag or supplier of Jenn-air oven controller for a replacement.
    Jul 13, 2009 | Jenn-Air Ovens
    Dacor model W305 blew an element. Replaced it. Won't work.
    The fan and element rely on a supply from the thermostat, so perhaps when the element blew, it damaged the thermostat, another possibility is that there is a fuse of some sort in the oven that has blown as a result of the element blowing.
    It is highly unlikely that the fan and element are faulty, you will have to look further.
    Plz rate this solution.
    Thanks, and merry xmas.
    Dec 20, 2008 | Ovens
    Jenn-Air WW30430W double oven flashing F7 and beeping
    It seems you have a stuck button. Here is a list of fault codes:
    Range/Stove/Oven Fault Codes
    Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
    Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
    Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
    1,168 people viewed this question
    Top Jenn-Air Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
