Question about Canon imageRUNNER 400S Copier
Printouts are too light, and have black lines through...
If I don't darken the density, the printouts are barely readable... if I darken the density, the printouts are mottled with dark lines.
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Drum is worn, replace.
Posted on Dec 06, 2007
IR 3035 black copy
On some types of paper (especially those with a high calcium carbonate content), toner offset to the fixing film can
start to cake, moving from the fixing film or the pressure roller to the face or back of paper.
<Field Remedy>
Use the following service mode item to change the timing at which the fixing pressure roller is cleaned:
0: disable cleaning (default)
1: execute cleaning during last rotation every 500 printouts
2: execute cleaning during last rotation every 200 printouts
3: execute cleaning during last rotation every 100 printouts
Feb 14, 2017 | Canon imageRUNNER 3035 Black and White...
Black colour lines in xerox only
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Jan 30, 2015 | Canon ImageRunner 4570 | IR4570 |
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
My HP business inkjet 2800 is producing printouts that are very faded and barely readable. The configuration page prints out only in black and white and indicates that the ink cartridges are all nearly...
The only thing to try is to run the cleaning software from 3-7 times, or until print quality is good. Right click the printer icon in the printer folder, select properties, then at the bottom click preferences. Locate maintainence, and run the clean and follow the instructions. If after 7 times the quality doesn't improve, you will have to replace the printheads. As long as the quality improves with each clean, continue to do so until it is acceptable.
Sep 30, 2010 | HP Business InkJet 2800 Printer
The print job for the TallyGenicom 6312 is a coupon and has a barcode in it, and the barcode is not readable by the barcode reader. The printed barcode looks perfect. And, the barcode reader has no...
Try to adjust the "Bar" setting in the Graphics menu. Here you can specify the density of the barcode. I have seen the best results using the Medium setting.
Jul 12, 2010 | TallyGenicom 6312 Matrix Printer
Lines coming out on printouts
I just developed the same problem....what was your solution?
Jun 05, 2010 | HP LaserJet 5p Printer
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
May 12, 2010 | Brother MFC 9700 All-In-One Laser Printer
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
Apr 12, 2010 | Ricoh Aficio CL7200 Laser Printer
Skipped Print Areas on Printouts
You may have a bad toner cartridge, if the cartridge has contaminants in it, it will not put toner on the drum in these areas, Try removing and giving the cartridge a good shake, try installing a new or at least another cartridge to see if the problem is here.
Hope this is of some help.
Apr 30, 2009 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
194 people viewed this question
old marine
old marine
