I have tried 3 different printers. My computer will not communicate with any of them. What settings on my computer might I need to change?
Do you have a firewall on your pc? send answer to [email protected] if so you may need to set it to accept your printer. also it could be the print function is disabled in your set up files .. feel free to respond to this and i will try to talk you through it .. dale
Wizard or u manualy boot from cd normaly u need instatlion cd 2 run printer if no cd go on lint get free download files good luck
SOURCE: computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
SOURCE: port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
All-in-ones usually have 2 phone jacks, a USB port and maybe even an Ethernet (big wide "phone jack" like connector)- any chance you have USB cable (which is how you print ands scan), pluged into the wrong port? is there a chance you usb cord is bad?
Lexmark can be awkward, though they don't mean to be. Do you have the original cd that came with your printer? If this is a computer problem, can you tell me what hardware you have? Computer - hp, dell, etc. And what version of Windows are you using? Because to be honest, if you connect correctly, any version of Windows in current use should find your printer and install it.
What printers? What operating system are you using?
